Hello Guest it is October 24, 2026, 11:43:44 AM
Author Topic: Needing help with Wizards  (Read 21631 times)
Re: Needing help with Wizards
« Reply #10 on: March 04, 2015, 04:14:21 PM »
That list was posted up a while back by Craig.
BTW: If you look in the Mach4 Toolbox, there are some wxWizard templates, as well as some controls examples,
that can help you get your head around the wxLua stuff.
Scott
« Reply #11 on: March 04, 2015, 04:15:09 PM »
The WxFormbuilder gives you about everything you need EXCEPT an EASY way to move things around . Wish we had a Screen Builder for Wizards like the MaCH4 Screen builder. OR hopefully someone in OZ will make a better WxBuilder that you can easily move things around.
Just a thought, (;-) TP
« Reply #12 on: March 05, 2015, 02:24:23 PM »
I also decided to side-step it.  It's another can of worms and if I need it, I'll open it.  ;)
As you may have already found out, you can pre-populate your wx.wxTextCtrl fields by setting something in the "value" box in wxFormBuilder.  I found this to be an acceptable compromise.
I have this figured out and working. It's not that bad of a process. You can pre-populate with the stored values (or strings) which is what I wanted to do. Sounds like you didn't want to fool with it, so I won't bother to post it.  If you decide otherwise, just give me a holler.
Thanks for the wxfunction listing!
