Hello Guest it is November 23, 2026, 10:16:07 PM
Author Topic: Master vs Slave axis pulsing difference on Mach3  (Read 21750 times)
Re: Master vs Slave axis pulsing difference on Mach3
« Reply #10 on: March 04, 2015, 04:42:20 AM »
Oups! you are right Ian: Mach3 is fine, and my recorder is wrong.
Reading again my code, I found I forgot to latch my positions counters (the ones that get incremented or decremented on PIN interrupts) before using them. As a result, by the time I output these to the serial port, they were altered by the interrupts.
Now I corrected the code, and everything is fine on both the parallel port and smoothstepper (just one pulse off on rare occasions, which is what one would expect).
I am very sorry about raising this false issue. I was too happy to find a beginning of solution for my still unexplained little wave patterns on the parts printed by the machine..
I will edit my first post, or maybe if a moderator is listening there, it might be better to just remove this all thread ?
Pierre
well, it seems I cannot edit my first post...
« Last Edit: March 04, 2015, 04:44:00 AM by fristot »
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #11 on: March 04, 2015, 05:04:11 AM »
That is a shame Ian, would have loved another reason to beat Brian over the head with regarding V066 :D
Can you not just beat him anyway?  >:D
Pierre - no worries - thanks for the update and hope you find the reason for your waves.
« Reply #12 on: March 04, 2015, 05:17:34 AM »
 I do Ian, at every opportunity I get. Sadly it makes little difference though.
