Hello Guest it is September 30, 2026, 03:24:41 PM
Author Topic: how to test the time since the start?  (Read 7277 times)
Offline v tec
  •  31 31
« on: February 14, 2015, 02:53:02 AM »
hi i use a gcode mixed with macro vb
my is code is for exemple
g00x1y1
m51
g00x10y10
m52
g000x0y0
m47
m30
m51 is for exemple
sub main()
if "time after start button" < 10sec then
activatesignal(ouput1)
exit sub
end if
end sub
and m52 is for exemple
sub main()
if "time after start button" > 10sec then
exit sub
end if
end sub
i try to test the led statut to the start button, but after m47 , it flash
the only solution is the the time dro, but i don t know the oem code
thanks
and sorry for my english
Re: how to test the time since the start?
« Reply #1 on: February 14, 2015, 02:12:51 PM »
Try this , SetTimer() starts a timer running when called, getTimer() gets the timer value.
M51
SetTimer(10)
end
M52
EndTime = GetTimer(10)
msgBox(""&EndTime)
