Hello Guest it is November 13, 2026, 12:45:31 PM
Author Topic: Start Up and Shut Down Procedure of Machine with regards to Homing  (Read 19260 times)
Re: Start Up and Shut Down Procedure of Machine with regards to Homing
« Reply #10 on: June 28, 2018, 01:26:50 PM »
when the machine is referenced then soft limits work.
I have roller plunger home switches on my mill which are repeatable to 0.02mm. It means that I can be half way through a job, stop, turn off the machine,
come back tomorrow, reference and start the job where I left off without having to reset anything.
Certainly you will 'zero' the machine relative to the surface or corner of the work but that is a relative position. Homing (referencing) is an absolute positioning
procedure.
