Hello Guest it is October 20, 2026, 03:50:39 PM
Author Topic: How Do I Trigger Output at Startup  (Read 19728 times)
Re: How Do I Trigger Output at Startup
« Reply #10 on: February 05, 2015, 01:16:24 PM »
It triggers relay 1 when I hit cycle start. I can manually hit them both at anytime with the mouse and trigger them. I think its controlled now under "spindle setup". In my PP i see the M3 command. So just for simplicity couldnt I edit my PP and have it trigger the 2nd relay with M7 or M8 OEM code 113 or 114?
« Reply #11 on: February 05, 2015, 02:02:33 PM »
Ok I got it to trigger by editing my PP. I added the M7 code. Thanks for all your help. Now if you know what code I can use to make everything pause while the spindle gets to speed ?
« Reply #12 on: February 05, 2015, 03:01:41 PM »
Config/ports and pins/spindle setup
