Hello Guest it is November 22, 2026, 09:07:08 AM
Author Topic: Can mach3 correct Z height along X and Y moves ?  (Read 8258 times)
« on: February 02, 2015, 02:47:58 AM »
Hello, I would like to know if it is possible to say mach3 for exemple to add 0.01X to Z and 0.005Y, to correct a inclined plane.
Re: Can mach3 correct Z height along X and Y moves ?
« Reply #1 on: February 02, 2015, 11:11:19 AM »
Mach3 CAN do mods to the axis's through the   "Formulas"  function. If you are trying to correct a BAD ALIGNED table you will be MUCH better off to just FIX the machine as any thing else is just a crutch and will bite you before it is all over.
Just a thought, (;-) TP
« Reply #2 on: February 02, 2015, 01:32:03 PM »
Very simple, thank you !
