Hello Guest it is October 20, 2026, 11:40:16 PM
Author Topic: machine percision  (Read 24250 times)
Re: machine percision
« Reply #10 on: February 04, 2015, 08:33:10 PM »
I went overthe hole machine to make sure everything is tight checked backlash. Had no backlash on x and .002 on y.  Reset steps and motor tuning  Checked steps on y to 11 inches and was exact on dial indicator. ran a 5 inch circle cut y cut to 5.034 and x cut to 5.014.  cut a 3 inch square y cut to 3.004 and x cut to 3.023.  Can the program be off im useing mill wizard.
Also when the program end i move the gantry out of the way a few inches then hit go to zero and its not in the same place.  My machine is chinese should i get new drivers if so what should i get.  Im getteing shielded wire and im going to redo all my cables
« Reply #11 on: February 05, 2015, 04:39:35 PM »
does anyone else have a problem with the mill wizard gcode . Just trying to figure out why stuff is not coming out right
« Reply #12 on: February 05, 2015, 09:03:11 PM »
Not sure what you mean by not in the same place.
Off a little or a lot?
Go To Zero - axis will move to the current offset if there is one........
« Reply #13 on: February 06, 2015, 10:15:34 AM »
When i set a piece to cut,i bring the router over to the center and zero the dro.  When the program is finished i move the router out of the way put a new piece of material in and hi go to zero. The dro goes to zero but the routers off between .030 and .070 most times not all the time
« Reply #14 on: February 06, 2015, 06:07:18 PM »
If your steps per unit are correct, backlash is set correctly, the axis mechancs are of reasonable quality and your velocity / accel
vlaues are proper for you machine, then I would guess that you should  do better than what you are seeing.
What more can I say................
« Reply #15 on: February 06, 2015, 08:29:28 PM »
Try reducing the X & Y axis's  Velocity and acceleration settings by 50% then retest. It sounds a lot like lost steps.
« Reply #16 on: February 07, 2015, 06:18:04 PM »
I will try the motor tuning again. I have the chinese controler and would like to up grade to equipment that will work best for me. I just dont know what to get. Do you guys have any suggestions on what i should get. What drivers and motors and mother board thing do you recomend.
« Reply #17 on: February 09, 2015, 03:09:38 PM »
I ordered a g540 and a new power supply and new stepper motors and cables.  Hopefully this will make me more accurate
