Hello Guest it is October 18, 2026, 11:19:05 AM
Author Topic: suggestions needed for setting up tailstock stepper on lathe  (Read 11972 times)
« on: January 31, 2015, 12:10:10 PM »
Hello Chaps
I am using a lathe with Mach3. I use screen 1024.lset ( the entry
level screen )
I have wired up a stepper motor to drive the tailstock  screw.
The ides is to use the tailstock for drilling  and  holding  the
rolling centre when machining  long shafts.
For drilling I dont think it will be  important ( for me at this stage anyway)
to be precise with dimensions and depth . All i really need at the
moment is to be able to put some code in which will drill a starting hole
in a solid rod before boring.
Again - for holding the rolling centre on a long shaft - will manufacture a
spring loaded rolling centre which will apply spring pressure to the
rolling centre to allow for small discrepancies in the shaft lengths.
The rolling centre will have a spring controlled travel of about 5 mm which
should be enough for what i want to do
I would appreciate advice and suggestions on doing the setup such as
which axis to use , which switches to activate , etc  and most importantly- where to
find the setup details in the operators manual
best regards and many thanks in advance
fred evans
« Reply #1 on: January 31, 2015, 05:19:35 PM »
As far as I know Mach3 Turn only supports 2 axes so I'm not sure how you can do this.
Sent from my iPad using Tapatalk
Re: suggestions needed for setting up tailstock stepper on lathe
« Reply #2 on: January 31, 2015, 06:25:27 PM »
Use the Mill screen.....lathe screen with a third axis on it ie; mine has an A axis which could be configured as linear rotation so you could play with  steps per unit for the Z direction move and set feedrate for drilling accordingly......swap axis ( rusty on that one).
Just some thoughts, ???
« Reply #3 on: January 31, 2015, 06:34:40 PM »
Unless I missed something you can use all 6 axis in TURN. You just have to setup the screen. (I just tried it here and it simulates just fine).
Set up C as linear and call it when needed.  You can even setup 2 buttons to extend and retract the Centerpoint or  use Gcode to do center drilling.
Just a thought, (;-)TP
« Reply #4 on: January 31, 2015, 06:41:51 PM »
Here is a link to a lathe screen with 3 axes on it. Has A but that could changed to something different.
Dump the original screen and use this one.
http://www.machsupport.com/forum/index.php/topic,13548.0.html
« Reply #5 on: February 01, 2015, 11:54:56 AM »
Hello chaps --0 thanks for the input
TP - your suggestion looks quite easy. when you say setup screen do i have to do
any work on screens like adding dros etc?. I havent got that far yet.
Rich i will download the sreeen you suggest. If I instal this new screen will its configuration
change the configuration of mt current 1025.lset screen?
My concern is that i find that i have to use the old screen while learning the new screen and
i dont want to find it broken if i choose to select the old screen.
regards
fred
« Reply #6 on: February 01, 2015, 01:28:11 PM »
If I instal this new screen will its configuration change the configuration of mt current 1025.lset screen?
Suggest you create  a new xml for using that screen from your current one.  The when using it, load the other screen instead of the 1024.lset.
