Hello Guest it is October 23, 2026, 06:53:09 PM
Author Topic: RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START  (Read 40176 times)
« on: January 31, 2015, 11:56:22 AM »
Hi
Not completely new here but was wondering if anyone can help me out with this problem.
Recently purchased Bobcad which is great very pleased. Having a problem with the Arc feature when posting to Mach3. I keep getting an error (RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START).
I scanned the forums and noticed a few people had the same problem but not using Bobcad. I have tried in gen config changing from absolute to inc mode and various other things as suggested but still keep getting the same error.
Any thoughts anyone?
Mick
Re: RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START
« Reply #1 on: January 31, 2015, 12:53:43 PM »
In Genconfig what have you got the IJ modes set to, INC or ABS. For most code it uses INC. The POST in Bobcam SHOULD be setting the IJ mode to which ever method the POST USES for IJ mode.
IN the Preamble blocks is there a G91.1 code?
« Reply #2 on: January 31, 2015, 01:36:13 PM »
Hi
In mach3 in general config I have IJ set to inc. The code bobcad is putting out is showing G91.1 at the beginning of the code.
Mick
« Reply #3 on: January 31, 2015, 02:02:46 PM »
OK how about distance mode  ABS or INC  , G90 or G91 in the preamble code
Post a copy of a simple program that shows the error.
« Last Edit: January 31, 2015, 02:05:37 PM by BR549 »
« Reply #4 on: January 31, 2015, 03:13:20 PM »
Hi
I have tried abs and inc in distance mode but get the same result. Here is the code that will not run:
(BEGIN PREDATOR NC HEADER)
(MCH_FILE=LATHE.MCH)
(END PREDATOR NC HEADER)
O00300 ( PROGRAM NUMBER )
( PROGRAM START - TURNING CYCLES )
( PROGRAM NAME: BALL.NC)
( POST: MACH 3 - METRIC )
( DATE: SAT. 01/31/2015)
( TIME: 01:34PM)
N01 G18 G21 G40 G80 G90 G99 G95
G91.1
(Machine Setup - 1  Turn Rough )
(TOOL #1    MASTER TOOL )
N02 G00 G54
N03 T0101 M06
N04 G97 S500 M04
N05 X17. Z-1.
N06 X15.8
N07 G01 Z-50. F.2
N08 G00 X16.
N09 Z-1.
N10 X15.6
N11 G01 Z-50. F.2
N12 G00 X15.8
N13 Z-1.
N14 X15.4
N15 G01 Z-50. F.2
N16 G00 X15.6
N17 Z-1.
N18 X15.2
N19 G01 Z-50. F.2
N20 G00 X15.4
N21 Z-1.
N22 X15.
N23 G01 Z-50. F.2
N24 G00 X17.
N25 X16.
N26 Z-1.
N27 G00 G54
N28 T0101
N29 G97 S500 M04
N30 X16. Z-1.
N31 X15.054
N32 G01 Z-13.539 F.2
N33 G03 X15.254 Z-16. K-15.187 I-2.473 F.2
N34 G00 Z-1.
N35 X14.854
N36 G01 Z-12.53 F.2
N37 X14.857 Z-12.543 F.2
N38 X15.051 Z-13.52 F.2
N39 X15.054 Z-13.539 F.2
N40 G00 Z-1.
N41 X14.654
N42 G01 Z-11.765 F.2
N43 X14.854 Z-12.53 F.2
N44 G00 Z-1.
N45 X14.454
N46 G01 Z-11.125 F.2
N47 X14.654 Z-11.765 F.2
N48 G00 Z-1.
N49 X14.254
N50 G01 Z-10.569 F.2
N51 X14.448 Z-11.106 F.2
N52 X14.454 Z-11.125 F.2
N53 G00 Z-1.
N54 X14.054
N55 G01 Z-10.071 F.2
N56 X14.254 Z-10.569 F.2
N57 G00 Z-1.
N58 X13.854
N59 G01 Z-9.618 F.2
N60 X14.054 Z-10.071 F.2
N61 G00 Z-1.
N62 X13.654
N63 G01 Z-9.2 F.2
N64 X13.854 Z-9.618 F.2
N65 G00 Z-1.
N66 X13.454
N67 G01 Z-8.812 F.2
N68 X13.46 Z-8.822 F.2
N69 X13.654 Z-9.2 F.2
N70 G00 Z-1.
N71 X13.254
N72 G01 Z-8.45 F.2
N73 X13.454 Z-8.812 F.2
N74 G00 Z-1.
N75 X13.054
N76 G01 Z-8.109 F.2
N77 X13.254 Z-8.45 F.2
N78 G00 Z-1.
N79 X12.854
N80 G01 Z-7.787 F.2
N81 X13.054 Z-8.109 F.2
N82 G00 Z-1.
N83 X12.654
N84 G01 Z-7.482 F.2
N85 X12.854 Z-7.787 F.2
N86 G00 Z-1.
N87 X12.454
N88 G01 Z-7.193 F.2
N89 X12.654 Z-7.482 F.2
N90 G00 Z-1.
N91 X12.254
N92 G01 Z-6.916 F.2
N93 X12.264 Z-6.929 F.2
N94 X12.454 Z-7.193 F.2
N95 G00 Z-1.
N96 X12.054
N97 G01 Z-6.653 F.2
N98 X12.254 Z-6.916 F.2
N99 G00 Z-1.
N100 X11.854
N101 G01 Z-6.4 F.2
N102 X12.054 Z-6.653 F.2
N103 G00 Z-1.
N104 X11.654
N105 G01 Z-6.158 F.2
N106 X11.854 Z-6.4 F.2
N107 G00 Z-1.
N108 X11.454
N109 G01 Z-5.926 F.2
N110 X11.645 Z-6.148 F.2
N111 X11.654 Z-6.158 F.2
N112 G00 Z-1.
N113 X11.254
N114 G01 Z-5.704 F.2
N115 X11.454 Z-5.926 F.2
N116 G00 Z-1.
N117 X11.054
N118 G01 Z-5.489 F.2
N119 X11.254 Z-5.704 F.2
N120 G00 Z-1.
N121 X10.854
N122 G01 Z-5.283 F.2
N123 X11.054 Z-5.489 F.2
N124 G00 Z-1.
N125 X10.654
N126 G01 Z-5.084 F.2
N127 X10.854 Z-5.283 F.2
N128 G00 Z-1.
N129 X10.454
N130 G01 Z-4.892 F.2
N131 X10.654 Z-5.084 F.2
N132 G00 Z-1.
N133 X10.254
N134 G01 Z-4.707 F.2
N135 X10.263 Z-4.714 F.2
N136 X10.446 Z-4.884 F.2
N137 X10.454 Z-4.892 F.2
N138 G00 Z-1.
N139 X10.054
N140 G01 Z-4.529 F.2
N141 X10.254 Z-4.707 F.2
N142 G00 Z-1.
N143 X9.854
N144 G01 Z-4.356 F.2
N145 X10.054 Z-4.529 F.2
N146 G00 Z-1.
N147 X9.654
N148 G01 Z-4.19 F.2
N149 X9.854 Z-4.356 F.2
N150 G00 Z-1.
N151 X9.454
N152 G01 Z-4.029 F.2
N153 X9.654 Z-4.19 F.2
N154 G00 Z-1.
N155 X9.254
N156 G01 Z-3.874 F.2
N157 X9.454 Z-4.029 F.2
N158 G00 Z-1.
N159 X9.054
N160 G01 Z-3.724 F.2
N161 X9.254 Z-3.874 F.2
N162 G00 Z-1.
N163 X8.854
N164 G01 Z-3.579 F.2
N165 X9.054 Z-3.724 F.2
N166 G00 Z-1.
N167 X8.654
N168 G01 Z-3.439 F.2
N169 X8.854 Z-3.579 F.2
N170 G00 Z-1.
N171 X8.454
N172 G01 Z-3.303 F.2
N173 X8.654 Z-3.439 F.2
N174 G00 Z-1.
N175 X8.254
N176 G01 Z-3.172 F.2
N177 X8.454 Z-3.303 F.2
N178 G00 Z-1.
N179 X8.054
N180 G01 Z-3.046 F.2
N181 X8.254 Z-3.172 F.2
N182 G00 Z-1.
N183 X7.854
N184 G01 Z-2.923 F.2
N185 X7.869 Z-2.932 F.2
N186 X8.054 Z-3.046 F.2
N187 G00 Z-1.
N188 X7.654
N189 G01 Z-2.805 F.2
N190 X7.854 Z-2.923 F.2
N191 G00 Z-1.
N192 X7.454
N193 G01 Z-2.691 F.2
N194 X7.654 Z-2.805 F.2
N195 G00 Z-1.
N196 X7.254
N197 G01 Z-2.582 F.2
N198 X7.438 Z-2.682 F.2
N199 X7.454 Z-2.691 F.2
N200 G00 Z-1.
N201 X7.054
N202 G01 Z-2.475 F.2
N203 X7.254 Z-2.582 F.2
N204 G00 Z-1.
N205 X6.854
N206 G01 Z-2.373 F.2
N207 X7.054 Z-2.475 F.2
N208 G00 Z-1.
N209 X6.654
N210 G01 Z-2.274 F.2
N211 X6.854 Z-2.373 F.2
N212 G00 Z-1.
N213 X6.454
N214 G01 Z-2.179 F.2
N215 X6.654 Z-2.274 F.2
N216 G00 Z-1.
N217 X6.254
N218 G01 Z-2.087 F.2
N219 X6.454 Z-2.179 F.2
N220 G00 Z-1.
N221 X6.054
N222 G01 Z-1.999 F.2
N223 X6.254 Z-2.087 F.2
N224 G00 Z-1.
N225 X5.854
N226 G01 Z-1.914 F.2
N227 X5.87 Z-1.921 F.2
N228 X6.054 Z-1.999 F.2
N229 G00 Z-1.
N230 X5.654
N231 G01 Z-1.833 F.2
N232 X5.854 Z-1.914 F.2
N233 G00 Z-1.
N234 X5.454
N235 G01 Z-1.755 F.2
N236 X5.64 Z-1.827 F.2
N237 X5.654 Z-1.833 F.2
N238 G00 Z-1.
N239 X5.254
N240 G01 Z-1.68 F.2
N241 X5.454 Z-1.755 F.2
N242 G00 Z-1.
N243 X5.054
N244 G01 Z-1.608 F.2
N245 X5.254 Z-1.68 F.2
N246 G00 Z-1.
N247 X4.854
N248 G01 Z-1.539 F.2
N249 X5.054 Z-1.608 F.2
N250 G00 Z-1.
N251 X4.654
N252 G01 Z-1.474 F.2
N253 X4.854 Z-1.539 F.2
N254 G00 Z-1.
N255 X4.454
N256 G01 Z-1.411 F.2
N257 X4.465 Z-1.414 F.2
N258 X4.654 Z-1.474 F.2
N259 G00 Z-1.
N260 X4.254
N261 G01 Z-1.351 F.2
N262 X4.454 Z-1.411 F.2
N263 G00 Z-1.
N264 X4.054
N265 G01 Z-1.295 F.2
N266 X4.254 Z-1.351 F.2
N267 G00 Z-1.
N268 X3.854
N269 G01 Z-1.241 F.2
N270 X4.054 Z-1.295 F.2
N271 G00 Z-1.
N272 X3.654
N273 G01 Z-1.191 F.2
N274 X3.854 Z-1.241 F.2
N275 G00 Z-1.
N276 X3.454
N277 G01 Z-1.143 F.2
N278 X3.654 Z-1.191 F.2
N279 G00 Z-1.
N280 X3.254
N281 G01 Z-1.097 F.2
N282 X3.26 Z-1.099 F.2
N283 X3.454 Z-1.143 F.2
N284 G00 Z-1.
N285 X3.054
N286 G01 Z-1.055 F.2
N287 X3.254 Z-1.097 F.2
N288 G00 Z-1.
N289 X2.854
N290 G01 Z-1.016 F.2
N291 X3.054 Z-1.055 F.2
N292 G00 Z-1.
N293 X2.772
N294 G01 X2.854 Z-1.016 F.2
N295 G00 X16.254
N296 X15.254
N297 Z-1.
(Machine Setup - 1  Turn Basic Finish )
N298 G00 G54
N299 T0101
N300 G97 S500 M04
N301 X16. Z-1.
N302 X-.1
N303 G03 X15. Z-16. K-.008 I-15.108 F.1
N304 G00 X30.
N305 Z-1.
N306 M05
N307 M02
« Reply #5 on: January 31, 2015, 04:23:08 PM »
There are several BAD things to that file.
Line33 should NOT be there as it will cut an arc right thru the untrimmed stock. It is cutt the ARC before the stock was rooughed to size. AND it is arced in the WRONG direction.
AND LINE 303 is cut in the wrong direction as well AND the arc is not even programmed correctly K/I is wrong.
Try this code.
( TIME: 01:34PM)
% G91.1
G90.1
N02 G00 G54
N03 T0101 M06
N04 G97 S500 M04
F500
N05 X17. Z-1.
N06 X15.8
N07 G01 Z-50. F100
N08 G00 X16.
N09 Z-1.
N10 X15.6
N11 G01 Z-50. F100
N12 G00 X15.8
N13 Z-1.
N14 X15.4
N15 G01 Z-50. F100
N16 G00 X15.6
N17 Z-1.
N18 X15.2
N19 G01 Z-50. F100
N20 G00 X15.4
N21 Z-1.
N22 X15.
N23 G01 Z-50. F100
N24 G00 X17.
N25 X16.
N26 Z-1.
N27 G00 G54
N28 T0101
N29 G97 S500 M04
N30 X16. Z-1.
N31 X15.054
N32 G01 Z-13.539 F100
(N33 G03 X15.254 Z-16. K-15.187 I-2.473 F100)
N34 G00 Z-1.
N35 X14.854
G90
N36 G01 Z-12.53 F100
N37 X14.857 Z-12.543 F100
N38 X15.051 Z-13.52 F100
N39 X15.054 Z-13.539 F100
N40 G00 Z-1.
N41 X14.654
N42 G01 Z-11.765 F100
N43 X14.854 Z-12.53 F100
N44 G00 Z-1.
N45 X14.454
N46 G01 Z-11.125 F100
N47 X14.654 Z-11.765 F100
N48 G00 Z-1.
N49 X14.254
N50 G01 Z-10.569 F100
N51 X14.448 Z-11.106 F100
N52 X14.454 Z-11.125 F100
N53 G00 Z-1.
N54 X14.054
N55 G01 Z-10.071 F100
N56 X14.254 Z-10.569 F100
N57 G00 Z-1.
N58 X13.854
N59 G01 Z-9.618 F100
N60 X14.054 Z-10.071 F100
N61 G00 Z-1.
N62 X13.654
N63 G01 Z-9.2 F100
N64 X13.854 Z-9.618 F100
N65 G00 Z-1.
N66 X13.454
N67 G01 Z-8.812 F100
N68 X13.46 Z-8.822 F100
N69 X13.654 Z-9.2 F100
N70 G00 Z-1.
N71 X13.254
N72 G01 Z-8.45 F100
N73 X13.454 Z-8.812 F100
N74 G00 Z-1.
N75 X13.054
N76 G01 Z-8.109 F100
N77 X13.254 Z-8.45 F100
N78 G00 Z-1.
N79 X12.854
N80 G01 Z-7.787 F100
N81 X13.054 Z-8.109 F100
N82 G00 Z-1.
N83 X12.654
N84 G01 Z-7.482 F100
N85 X12.854 Z-7.787 F100
N86 G00 Z-1.
N87 X12.454
N88 G01 Z-7.193 F100
N89 X12.654 Z-7.482 F100
N90 G00 Z-1.
N91 X12.254
N92 G01 Z-6.916 F100
N93 X12.264 Z-6.929 F100
N94 X12.454 Z-7.193 F100
N95 G00 Z-1.
N96 X12.054
N97 G01 Z-6.653 F100
N98 X12.254 Z-6.916 F100
N99 G00 Z-1.
N100 X11.854
N101 G01 Z-6.4 F100
N102 X12.054 Z-6.653 F100
N103 G00 Z-1.
N104 X11.654
N105 G01 Z-6.158 F100
N106 X11.854 Z-6.4 F100
N107 G00 Z-1.
N108 X11.454
N109 G01 Z-5.926 F100
N110 X11.645 Z-6.148 F100
N111 X11.654 Z-6.158 F100
N112 G00 Z-1.
N113 X11.254
N114 G01 Z-5.704 F100
N115 X11.454 Z-5.926 F100
N116 G00 Z-1.
N117 X11.054
N118 G01 Z-5.489 F100
N119 X11.254 Z-5.704 F100
N120 G00 Z-1.
N121 X10.854
N122 G01 Z-5.283 F100
N123 X11.054 Z-5.489 F100
N124 G00 Z-1.
N125 X10.654
N126 G01 Z-5.084 F100
N127 X10.854 Z-5.283 F100
N128 G00 Z-1.
N129 X10.454
N130 G01 Z-4.892 F100
N131 X10.654 Z-5.084 F100
N132 G00 Z-1.
N133 X10.254
N134 G01 Z-4.707 F100
N135 X10.263 Z-4.714 F100
N136 X10.446 Z-4.884 F100
N137 X10.454 Z-4.892 F100
N138 G00 Z-1.
N139 X10.054
N140 G01 Z-4.529 F100
N141 X10.254 Z-4.707 F100
N142 G00 Z-1.
N143 X9.854
N144 G01 Z-4.356 F100
N145 X10.054 Z-4.529 F100
N146 G00 Z-1.
N147 X9.654
N148 G01 Z-4.19 F100
N149 X9.854 Z-4.356 F100
N150 G00 Z-1.
N151 X9.454
N152 G01 Z-4.029 F100
N153 X9.654 Z-4.19 F100
N154 G00 Z-1.
N155 X9.254
N156 G01 Z-3.874 F100
N157 X9.454 Z-4.029 F100
N158 G00 Z-1.
N159 X9.054
N160 G01 Z-3.724 F100
N161 X9.254 Z-3.874 F100
N162 G00 Z-1.
N163 X8.854
N164 G01 Z-3.579 F100
N165 X9.054 Z-3.724 F100
N166 G00 Z-1.
N167 X8.654
N168 G01 Z-3.439 F100
N169 X8.854 Z-3.579 F100
N170 G00 Z-1.
N171 X8.454
N172 G01 Z-3.303 F100
N173 X8.654 Z-3.439 F100
N174 G00 Z-1.
N175 X8.254
N176 G01 Z-3.172 F100
N177 X8.454 Z-3.303 F100
N178 G00 Z-1.
N179 X8.054
N180 G01 Z-3.046 F100
N181 X8.254 Z-3.172 F100
N182 G00 Z-1.
N183 X7.854
N184 G01 Z-2.923 F100
N185 X7.869 Z-2.932 F100
N186 X8.054 Z-3.046 F100
N187 G00 Z-1.
N188 X7.654
N189 G01 Z-2.805 F100
N190 X7.854 Z-2.923 F100
N191 G00 Z-1.
N192 X7.454
N193 G01 Z-2.691 F100
N194 X7.654 Z-2.805 F100
N195 G00 Z-1.
N196 X7.254
N197 G01 Z-2.582 F100
N198 X7.438 Z-2.682 F100
N199 X7.454 Z-2.691 F100
N200 G00 Z-1.
N201 X7.054
N202 G01 Z-2.475 F100
N203 X7.254 Z-2.582 F100
N204 G00 Z-1.
N205 X6.854
N206 G01 Z-2.373 F100
N207 X7.054 Z-2.475 F100
N208 G00 Z-1.
N209 X6.654
N210 G01 Z-2.274 F100
N211 X6.854 Z-2.373 F100
N212 G00 Z-1.
N213 X6.454
N214 G01 Z-2.179 F100
N215 X6.654 Z-2.274 F100
N216 G00 Z-1.
N217 X6.254
N218 G01 Z-2.087 F100
N219 X6.454 Z-2.179 F100
N220 G00 Z-1.
N221 X6.054
N222 G01 Z-1.999 F100
N223 X6.254 Z-2.087 F100
N224 G00 Z-1.
N225 X5.854
N226 G01 Z-1.914 F100
N227 X5.87 Z-1.921 F100
N228 X6.054 Z-1.999 F100
N229 G00 Z-1.
N230 X5.654
N231 G01 Z-1.833 F100
N232 X5.854 Z-1.914 F100
N233 G00 Z-1.
N234 X5.454
N235 G01 Z-1.755 F100
N236 X5.64 Z-1.827 F100
N237 X5.654 Z-1.833 F100
N238 G00 Z-1.
N239 X5.254
N240 G01 Z-1.68 F100
N241 X5.454 Z-1.755 F100
N242 G00 Z-1.
N243 X5.054
N244 G01 Z-1.608 F100
N245 X5.254 Z-1.68 F100
N246 G00 Z-1.
N247 X4.854
N248 G01 Z-1.539 F100
N249 X5.054 Z-1.608 F100
N250 G00 Z-1.
N251 X4.654
N252 G01 Z-1.474 F100
N253 X4.854 Z-1.539 F100
N254 G00 Z-1.
N255 X4.454
N256 G01 Z-1.411 F100
N257 X4.465 Z-1.414 F100
N258 X4.654 Z-1.474 F100
N259 G00 Z-1.
N260 X4.254
N261 G01 Z-1.351 F100
N262 X4.454 Z-1.411 F100
N263 G00 Z-1.
N264 X4.054
N265 G01 Z-1.295 F100
N266 X4.254 Z-1.351 F100
N267 G00 Z-1.
N268 X3.854
N269 G01 Z-1.241 F100
N270 X4.054 Z-1.295 F100
N271 G00 Z-1.
N272 X3.654
N273 G01 Z-1.191 F100
N274 X3.854 Z-1.241 F100
N275 G00 Z-1.
N276 X3.454
N277 G01 Z-1.143 F100
N278 X3.654 Z-1.191 F100
N279 G00 Z-1.
N280 X3.254
N281 G01 Z-1.097 F100
N282 X3.26 Z-1.099 F100
N283 X3.454 Z-1.143 F100
N284 G00 Z-1.
N285 X3.054
N286 G01 Z-1.055 F100
N287 X3.254 Z-1.097 F100
N288 G00 Z-1.
N289 X2.854
N290 G01 Z-1.016 F100
N291 X3.054 Z-1.055 F100
N292 G00 Z-1.
N293 X2.772
N294 G01 X2.854 Z-1.016 F100
N295 G00 X16.254
N296 X15.254
N297 Z-1.
N298 G00 G54
N299 T0101
N300 G97 S500 M04
N301 X16. Z-1.
N302 X-.1
(N303 G03 X15. Z-16. K-.008 I-15.108 F10)
N303 G02 X15.254 Z-16. K-15.187 I-2.473 F100
N304 G00 X30.
N305 Z-1.
N306 M05
N307 M02
« Reply #6 on: January 31, 2015, 04:48:16 PM »
Thanks for that I will try it.
 What I don't under stand is the program ran fine in the Bobcad simulation and its Bobcad outputting the code.
Mick
« Reply #7 on: January 31, 2015, 04:57:24 PM »
The SIM modual and the POST modual are two different critters. Obivously the POST is outputting incorrect Gcode (not unusual for BobCam Posts).
Just a thought, (;-) TP
« Reply #8 on: January 31, 2015, 05:14:29 PM »
Hi
I have just re drawn the ball in Bobcad and tried it again and it seems to work. I think maybe with chopping and changing it, it was me causing the problem. Here's the code it now gives me.
Does this look right?
O00100 ( PROGRAM NUMBER )
( TIME: 11:07PM)
G91.1
(Machine Setup - 1  FACE OFF )
(TOOL #1    FACING******** )
N02 G00 G54
N03 T0101 M06
N04 G97 S500 M03
N05 X16. Z1.
N06 Z-.3
N07 G01 X0. F.2
N08 G00 Z0.
N09 X16.
N10 Z-.6
N11 G01 X0. F.2
N12 G00 Z-.3
N13 X16.
N14 Z-.9
N15 G01 X0. F.2
N16 G00 Z-.6
N17 X16.
N18 Z-1.
N19 G01 X0. F.2
N20 G00 Z1.
N21 X16.
N22 Z0.
(Machine Setup - 1  TURN OUTER )
(TOOL #2    TURNING***************** )
N23 G00 G54
N24 T0202 M06
N25 G97 S500 M03
N26 X17. Z0.
N27 X15.7
N28 G01 Z-50. F.2
N29 G00 X16.
N30 Z0.
N31 X15.4
N32 G01 Z-50. F.2
N33 G00 X15.7
N34 Z0.
N35 X15.1
N36 G01 Z-50. F.2
N37 G00 X15.4
N38 Z0.
N39 X15.
N40 G01 Z-50. F.2
N41 G00 X17.
N42 X16.
N43 Z0.
(Machine Setup - 1  TURN ARC )
(TOOL #3    ARC )
N44 G00 G54
N45 T0303 M06
N46 G97 S500 M03
N47 X16. Z-1.
N48 X14.7
N49 G01 Z-13.017 F.2
N50 G03 X15. Z-16. K-14.708 I-2.986 F.2
N51 G00 Z-1.
N52 X14.4
N53 G01 Z-11.802 F.2
N54 G03 X14.7 Z-13.017 K-14.407 I-4.201 F.2
N55 G00 Z-1.
N56 X14.1
N57 G01 Z-10.884 F.2
N58 X14.4 Z-11.802 F.2
N59 G00 Z-1.
N60 X13.8
N61 G01 Z-10.122 F.2
N62 X14.1 Z-10.884 F.2
N63 G00 Z-1.
N64 X13.5
N65 G01 Z-9.463 F.2
N66 X13.8 Z-10.122 F.2
N67 G00 Z-1.
N68 X13.2
N69 G01 Z-8.876 F.2
N70 X13.5 Z-9.463 F.2
N71 G00 Z-1.
N72 X12.9
N73 G01 Z-8.346 F.2
N74 X13.2 Z-8.876 F.2
N75 G00 Z-1.
N76 X12.6
N77 G01 Z-7.861 F.2
N78 X12.607 Z-7.872 F.2
N79 X12.9 Z-8.346 F.2
N80 G00 Z-1.
N81 X12.3
N82 G01 Z-7.415 F.2
N83 X12.6 Z-7.861 F.2
N84 G00 Z-1.
N85 X12.
N86 G01 Z-7.001 F.2
N87 X12.3 Z-7.415 F.2
N88 G00 Z-1.
N89 X11.7
N90 G01 Z-6.614 F.2
N91 X12. Z-7.001 F.2
N92 G00 Z-1.
N93 X11.4
N94 G01 Z-6.252 F.2
N95 X11.7 Z-6.614 F.2
N96 G00 Z-1.
N97 X11.1
N98 G01 Z-5.911 F.2
N99 X11.114 Z-5.927 F.2
N100 X11.4 Z-6.252 F.2
N101 G00 Z-1.
N102 X10.8
N103 G01 Z-5.591 F.2
N104 X11.1 Z-5.911 F.2
N105 G00 Z-1.
N106 X10.5
N107 G01 Z-5.289 F.2
N108 X10.8 Z-5.591 F.2
N109 G00 Z-1.
N110 X10.2
N111 G01 Z-5.002 F.2
N112 X10.5 Z-5.289 F.2
N113 G00 Z-1.
N114 X9.9
N115 G01 Z-4.731 F.2
N116 X10.2 Z-5.002 F.2
N117 G00 Z-1.
N118 X9.6
N119 G01 Z-4.475 F.2
N120 X9.89 Z-4.722 F.2
N121 X9.9 Z-4.731 F.2
N122 G00 Z-1.
N123 X9.3
N124 G01 Z-4.231 F.2
N125 X9.6 Z-4.475 F.2
N126 G00 Z-1.
N127 X9.
N128 G01 Z-4.001 F.2
N129 X9.3 Z-4.231 F.2
N130 G00 Z-1.
N131 X8.7
N132 G01 Z-3.781 F.2
N133 X9. Z-4.001 F.2
N134 G00 Z-1.
N135 X8.4
N136 G01 Z-3.573 F.2
N137 X8.7 Z-3.781 F.2
N138 G00 Z-1.
N139 X8.1
N140 G01 Z-3.375 F.2
N141 X8.4 Z-3.573 F.2
N142 G00 Z-1.
N143 X7.8
N144 G01 Z-3.188 F.2
N145 X8.1 Z-3.375 F.2
N146 G00 Z-1.
N147 X7.5
N148 G01 Z-3.01 F.2
N149 X7.8 Z-3.188 F.2
N150 G00 Z-1.
N151 X7.2
N152 G01 Z-2.842 F.2
N153 X7.5 Z-3.01 F.2
N154 G00 Z-1.
N155 X6.9
N156 G01 Z-2.682 F.2
N157 X7.2 Z-2.842 F.2
N158 G00 Z-1.
N159 X6.6
N160 G01 Z-2.53 F.2
N161 X6.9 Z-2.682 F.2
N162 G00 Z-1.
N163 X6.3
N164 G01 Z-2.388 F.2
N165 X6.6 Z-2.53 F.2
N166 G00 Z-1.
N167 X6.
N168 G01 Z-2.253 F.2
N169 X6.3 Z-2.388 F.2
N170 G00 Z-1.
N171 X5.7
N172 G01 Z-2.126 F.2
N173 X6. Z-2.253 F.2
N174 G00 Z-1.
N175 X5.4
N176 G01 Z-2.006 F.2
N177 X5.7 Z-2.126 F.2
N178 G00 Z-1.
N179 X5.1
N180 G01 Z-1.894 F.2
N181 X5.4 Z-2.006 F.2
N182 G00 Z-1.
N183 X4.8
N184 G01 Z-1.789 F.2
N185 X4.822 Z-1.796 F.2
N186 X5.1 Z-1.894 F.2
N187 G00 Z-1.
N188 X4.5
N189 G01 Z-1.691 F.2
N190 X4.8 Z-1.789 F.2
N191 G00 Z-1.
N192 X4.2
N193 G01 Z-1.6 F.2
N194 X4.5 Z-1.691 F.2
N195 G00 Z-1.
N196 X3.9
N197 G01 Z-1.516 F.2
N198 X4.2 Z-1.6 F.2
N199 G00 Z-1.
N200 X3.6
N201 G01 Z-1.439 F.2
N202 X3.882 Z-1.511 F.2
N203 X3.9 Z-1.516 F.2
N204 G00 Z-1.
N205 X3.3
N206 G01 Z-1.368 F.2
N207 X3.6 Z-1.439 F.2
N208 G00 Z-1.
N209 X3.
N210 G01 Z-1.303 F.2
N211 X3.3 Z-1.368 F.2
N212 G00 Z-1.
N213 X2.7
N214 G01 Z-1.245 F.2
N215 X3. Z-1.303 F.2
N216 G00 Z-1.
N217 X2.4
N218 G01 Z-1.194 F.2
N219 X2.685 Z-1.242 F.2
N220 X2.7 Z-1.245 F.2
N221 G00 Z-1.
N222 X2.1
N223 G01 Z-1.148 F.2
N224 X2.4 Z-1.194 F.2
N225 G00 Z-1.
N226 X1.8
N227 G01 Z-1.109 F.2
N228 X2.1 Z-1.148 F.2
N229 G00 Z-1.
N230 X1.5
N231 G01 Z-1.075 F.2
N232 X1.8 Z-1.109 F.2
N233 G00 Z-1.
N234 X1.2
N235 G01 Z-1.048 F.2
N236 X1.226 Z-1.05 F.2
N237 X1.47 Z-1.072 F.2
N238 X1.5 Z-1.075 F.2
N239 G00 Z-1.
N240 X.9
N241 G01 Z-1.027 F.2
N242 X1.2 Z-1.048 F.2
N243 G00 Z-1.
N244 X.6
N245 G01 Z-1.013 F.2
N246 X.9 Z-1.027 F.2
N247 G00 Z-1.
N248 X.3
N249 G01 Z-1.003 F.2
N250 X.6 Z-1.013 F.2
N251 G00 Z-1.
N252 X0.
N253 G01 X.3 Z-1.003 F.2
N254 G00 X16.
N255 X15.
N256 Z-1.
N257 M05
N258 M02
« Reply #9 on: February 01, 2015, 03:52:47 AM »
Code looks fine, its in radius mode, so looked a bit funny until I changed that.
