Hello Guest it is November 13, 2026, 12:24:11 PM
Author Topic: parameter syntax  (Read 10388 times)
parameter syntax
« on: January 24, 2015, 11:42:56 PM »
Hello chaps
I am doing a bit of coding with parameters and having trouble getting mach3 to read them
I think it is a syntax error.
firstly -do the normal operators ("+","-","/","*') work on parms??
secondly what about boolean ?
What about "<" and ">" (smaller than and bigger than)
thirdly where do the brackets go?
this is one of the lines i am not getting
Plain english says  #5  is equal to #3 minus 2 mm
coded as follows   #5=#3-2  doesnt work ??
please help the manual is very brief on this subject is there ant other literature?
regards
fred
think of the trees-- use both sides of the computer paper
Re: parameter syntax
« Reply #1 on: January 25, 2015, 12:18:54 AM »
#5 = [#2-2]
« Reply #2 on: January 25, 2015, 06:03:22 AM »
sorry i didnt make it clear
values of parms are as follows
# 3=9
To get value of #5 I am looking for 9-2
#5 = #3-2 ( answer should be
value of #5=7)
« Reply #3 on: January 25, 2015, 11:53:55 AM »
Ha-- square brackets . Is that the secret?
Fred
« Reply #4 on: January 25, 2015, 11:58:09 AM »
#3 = 9
#5 =[#3 -2]
