Hello Guest it is November 26, 2026, 04:22:04 PM
Author Topic: slow Ref All Axis speed for Homing?  (Read 10643 times)
Offline Frank1959
  •  38 38
  • Do it, it´ll free your mind.
    • Monumental Sculpture
« on: January 16, 2015, 04:46:20 AM »
Hia all,
When I Reference my A or X  axis, either in Diagnostics or using Ref All Axis, both my X axis and my A axis usually  overrun the Home switch, because both axis move/spin  quite quickly, causing the Limit switch (on the X axis) to trip.
 On the A axis, the result is that sometimes it homes on one side of the steel slug bolted to the chuck, that passes in front of the proximity switch, but if it overruns, it homes on the other side, giving about a 30 degree difference in the chuck position.
I´ve just read on page 4-10 of the MACH Manual Rev 1.84-A2, that the axis will travel “at a selectable low speed”.
Can anyone tell me where that parameter is selected?
Regards and thanks,
Frank
Re: slow Ref All Axis speed for Homing?
« Reply #1 on: January 16, 2015, 06:27:34 AM »
Config menu then Homing and Limits, you can set the speed there as a 5 of the rapid for that axis.
« Reply #2 on: January 16, 2015, 06:49:25 AM »
"Config menu then Homing and Limits, you can set the speed there as a % of the rapid for that axis.
Hood"
(intermittent Shift key) :)
Russ
« Reply #3 on: January 16, 2015, 06:52:37 AM »
Nah, frozen bloody fingers, its like the ice age all over again in the workshop.
Offline Frank1959
  •  38 38
« Reply #4 on: January 18, 2015, 05:15:04 AM »
Many thanks to both Hood and his frozen fingers  ;D and Overloaded for being there too.
Did that, works great !!!
Frank.
www.franknorton.com
