Hello Guest it is October 11, 2026, 01:33:19 AM
Author Topic: Mach3 reads dro as inches - displays mm  (Read 9175 times)
« on: January 14, 2015, 11:26:23 AM »
I wrote a short program about a year ago and as i rerun it now there is a strange occurrence
i use the buttons to "set home x"  and "set home Z "
the machine is set for mm in the general config
the machine homes correctly just touching off on the home switches.
 Now i want to set thwe axis position of the z axix to be z+8. ( this means that 0 (zero)
will be 8 mm to the left of the home position.
when i enter "8" into the dro the dro converts this to "203.4" which means that it has
read the input as 8 inches instead of 8mm and then converted the input to "203.4"
which is the length of 8 inches expressed in mm.
Why is it doing this?
best regards
fred
Re: Mach3 reads dro as inches - displays mm
« Reply #1 on: January 14, 2015, 03:36:58 PM »
Does your code have G20 in it or does the Init string at the top show a G20?
« Reply #2 on: January 16, 2015, 11:44:25 AM »
Thanks Hood--
there was a g20 in the code - i changed it to g21 and looks like problem solved
fred
