Hello Guest it is October 24, 2026, 09:45:54 PM
Author Topic: toolpost help needed  (Read 18624 times)
Re: toolpost help needed
« Reply #10 on: January 15, 2015, 02:07:46 PM »
T0705 or T705 will work fine and do the same. You dont need the M6 in Turn although it should do no harm if you include it.
To get that message you would have to have a tool call with greater than 99 for the tool number, so unless you called something like t10705 then I do not know why you would see that.
062 or thereabouts is what I use, so do not think that will be the problem.
« Reply #11 on: January 15, 2015, 02:14:03 PM »
thank you for all your help i will have another look at the machine tomorrow
robert
