Hello Guest it is October 10, 2026, 10:10:27 PM
Author Topic: Position Errors Only on Diagonal Moves  (Read 80576 times)
Re: Position Errors Only on Diagonal Moves
« Reply #30 on: January 15, 2015, 10:20:43 AM »
Hi Nate,
Back plotting your code, I see that the lead in/out looks a bit peculiar.
I wonder if that might be contributing ?
Maybe adjust the code and run the same profiles but without any leadins/outs ?
Just a guess, ::)
Russ
« Reply #31 on: January 15, 2015, 10:23:08 AM »
Russ,
That's the transition between the roughing and finishing passes.  The actual lead-in and lead-out are just straight Z moves.
« Reply #32 on: January 15, 2015, 10:31:14 AM »
Running your Gcode, using a laser, the centreline of the toolpath produces a 1.2" square on the first pass and a 1.25" square on the second pass. Both the X-Y aligned square and the 45 deg. square are absolutely identical in dimension - there is no error.
So I think I can safely say there is absolutely nothing wrong with your Gcode or the Mach3 interpretation of that Gcode.
Hope this helps in finding your problem.
Tweakie,
I am inclined to agree with you, especially after I:
  - took a known good control computer from another machine and upon hooking it to the mill it produced the same off results.
  - rebuilt the configure file from a pristine manufacturers file and a second time from scratch and still got the same off results.
  - get the same results using the PP or a UC100
My only question is, what do I check now?
Nate
Fine Line Automation
www.finelineautomation.com
« Reply #33 on: January 15, 2015, 10:43:23 AM »
Ray,
 Watching this run Single Step, you can see that the rough pass plunges straight in, but it stays at depth and does the S shaped lead in to the finish pass.
If I see it right.
Russ
  •  9,374 9,374
« Reply #34 on: January 15, 2015, 10:55:54 AM »
Hi Nate,
It beats me but I think you have ruled out everything but your machine electrical's and the tuning of your servo's.
Are all your voltages correct and being maintained during the run ? - Are all your electrical connectors truly sound ?
« Reply #35 on: January 15, 2015, 11:30:21 AM »
Ray,
If I see it right.
Russ
Russ,
Yes, that is exactly right.
« Reply #36 on: January 15, 2015, 11:35:21 AM »
Thanks Ray
Ok, I'm curious ....  just 1 more and I'll stay out ..
You've had this machine about a year, and has it ever run any decent parts?
Any diag. interpolated move is trash?
I see it stated where CAM and hand coding does the same.
Did you try a simple point to point rotated square pattern of 4 holes maybe ?
Start at X0,Y0
X1
hole
X0 Y1
hole
X-1 Y0
hole
X0 Y-1
hole
Then measure.
Just wondering if you tried something this simple as a test  ?
This would maybe eliminate some possibilities.
Russ
« Reply #37 on: January 15, 2015, 11:44:21 AM »
Hi Nate,
It has AC servos, powered directly off the 220VAC line, so supply power is not an issue.
What baffles me is it would have to be a problem in BOTH the X and Y drives as both are going to the wrong position.  But what would cause it to only happen on coordinated moves?
Very odd problem indeed....
« Reply #38 on: January 15, 2015, 12:50:50 PM »
Ray did you measure the Square from corner to corner to check for square or just side to side ??
Have you tried a SIMPLE test with just the basic moves . only one cut, no finish cuts,No offseting , no tool changing etc?
G20 (Units: Inches)
G40 G90 G91.1 G49 G80
F1
(Part: TestSquare)
G0 Z1.000
G00 X0.8839 Y0.0000
G01 Z-0.010 F10.0
X0.0000 Y0.8839 F17.0
X0.8839 Y1.7678
X1.7678 Y0.8839
X0.8839 Y0.0000
G00 Z0.5000
X3.4008 Y0.8839
G01 Z-.010 F10.0
Y0.2589 F17.0
X2.1508
Y1.5089
X3.4008
Y0.8834
G00 Z0.5000
M05 M30
« Reply #39 on: January 15, 2015, 01:19:53 PM »
Then one more test to change the way it is programmed.
(TestSquare2.txt)
G20 (Units: Inches)
G40 G90 G91.1 G49 G80 G69
F1
(Part: TestSquare)
G00 Z1.000
G00 X0.000 Y0.000
G00 Z0.010
G01 Z-.010 F10.0
G91
G1 X2.000  F20
Y2.000
X-2.000
Y-2.000
G90
G00 Z0.5000
G91
G00 X4
G90
G68  R45
G90
G1 Z-.010 F10
G91
G1 X2.000  F20
Y2.000
X-2.000
Y-2.000
G90
G0 Z0.5000
G69
G0X0.000 Y0.000
M05 M30
