Hello Guest it is November 12, 2026, 07:04:48 AM
Author Topic: Position Errors Only on Diagonal Moves  (Read 82125 times)
Re: Position Errors Only on Diagonal Moves
« Reply #10 on: January 14, 2015, 12:45:27 PM »
OK next test Does it cut exactly the same IF you reverse the order of cut From  CW to CCW. IS the offsetting of the cut the same ??
Terry,
Good question!  I think we tried that, but not 100% sure.  I'll make sure we try that.
« Reply #11 on: January 14, 2015, 12:46:47 PM »
If it’s any help to the discussion I have just been and cut two 50mm squares, one on the X-Y axis and one at 45 deg. They were both cut ‘on the line’ with a laser so turned out 49.4mm x 49.4mm but they both measure identical.
Doesn't surprise me.  I'm sure this is something in this machine, or Mach3 install.
« Reply #12 on: January 14, 2015, 12:47:40 PM »
Is the 0,0 part position at the center of the square ? or elsewhere ? (at a corner)
Might try it both ways just to see if there's a difference there.
I would, but can't right now.
Russ
It's generally been off to the left, but perhaps not always.  I'll have to check.
« Reply #13 on: January 14, 2015, 01:38:26 PM »
Well, I am the friend that's been having issues. Here is the thread on cnczone: http://www.cnczone.com/forums/showpost.php?p=1624744 this thread documents the tests I have run now.
The code is generated in HSMXpress. As Ray noted, it has been hand checked. I have generated code that had the origin:
  - in the center of the square.
  - at points below and left of the square
  - at points above and left of the square
  - at points below and right of the square
  - at points above and right of the square
In all cases my 90 degree squares (sides parallel to the x and y axes) come out perfect. My 45 degree 1" wide squares (sides are 45 degrees from the x and Y axes) are always coming out .956 in one direction and 1.042 in the other.
Note that I set up dial indicators and did testing for lost steps as well as for backlash and neither are occurring.
Not on that thread but another data point: I took the control computer from one of the CNC routers in my shop and put it on the mill. That Mach 3 installation functions perfectly on the CNC router. I copied over the mill XML profile and ran the test again. It came out with the same dimensions.
« Reply #14 on: January 14, 2015, 02:17:31 PM »
The resultant box cut on the diagonal acts like it is a mechanical backlash problem in one axis only.
Also, if there is a mechanical problem, it cannot cut a perfect circle.
The problem may only show up when both axis are under load, versus the cutting the box with sides parallel to x and y.
Also, check the gibs in the head, using a long bar lever. If the machine is new, something may have been overlooked
in the assembly, like final clearance adjustment.
John
« Reply #15 on: January 14, 2015, 03:16:50 PM »
Then create a new .xml from scratch and try it.
« Reply #16 on: January 14, 2015, 03:34:38 PM »
John
The machine is about 1 year old. To test backlash under load, I ran the square test with a engraving bit going only .01" deep. Just enough to score the part. The spindle load meter was at 2% the whole time. It still came out the same.
I first thought it was lost steps or backlash. I measured my backlash according to this video: http://www.youtube.com/watch?v=buXHZ_McbOY and I got less than .001" on each axis. Even if there was backlash due to load, the square is off by 0.042" in each direction, which is at least 10x the amount I would reasonably expect. I also did extensive testing for lost steps and my indicators read no steps through the entirety of my testing.
My next steps for testing will be:
  - cut the square backwards and see if it's different.
  - swap the X and Y servo drives and see if that reverses the cut.
« Reply #17 on: January 14, 2015, 03:37:29 PM »
In a separate test, I had the manufacturer send me a vanilla xml they use for the machines and I tried that. I also tried redoing it from scratch. I tried with just the PP. I tried with a UC100 motion controller. The square came out off by the same amount for all of them.
« Reply #18 on: January 14, 2015, 03:51:11 PM »
Have you tried it with a G4P1 at the end of each move?
Can you monitor the encoder position in the servo drive software? (not sure what drives you have)
« Reply #19 on: January 14, 2015, 04:16:56 PM »
Ray said this was a bed mill. Is it a commercial metal cutting mill ? Or more of a hobby level type ?
Just curious.
Russ
« Last Edit: January 14, 2015, 04:48:40 PM by Overloaded »
