Hello Guest it is November 23, 2026, 09:07:33 PM
Author Topic: coil winder spindle control  (Read 9165 times)
« on: January 12, 2015, 06:24:10 AM »
Hello,
I have built small coil winding machine whose wire guide is controlled using x,y and z axis of mach3. The spindle is servo motor controlled on A axis. While winding my g code goes like,
G0 A0Y0
G0A30Y10       layer 1
G0A60Y0          layer 2
G0A90Y10       layer 3
G0A120Y0       layer 4
and so on.
 The problem is at every end spindle stops with defined accn and dccn time which is very time consuming.
How can I continuously run the spindle without stopping at the end of every layer?
pl help.
deepak
  •  9,378 9,378
Re: coil winder spindle control
« Reply #1 on: January 12, 2015, 11:02:40 AM »
I think your best bet is to increase the Acceleration settings in Motor Tuning.. If you need a slow start then make your first move a G01 at a lesser feed rate.
« Reply #2 on: January 12, 2015, 01:24:18 PM »
Are you in Exact Stop mode?
On the coil winder I did the spindle doesnt stop, in fact it hardly slows, I use CV mode.
