Hello Guest it is October 24, 2026, 04:22:18 PM
Author Topic: incremental encoder 10.000 RPM  (Read 67564 times)
Re: incremental encoder 10.000 RPM
« Reply #20 on: January 08, 2015, 06:16:08 PM »
there I even thought about but do not know how to set that than in Mach3? Pulley 1/2 ??
grtz
« Reply #21 on: January 08, 2015, 06:20:56 PM »
Afraid not, the CS-Lab products use full encoder for lathe threading and it needs to be 1:1.
On the small lathe I had a servo motor geared 2:1 and I used the motors encoder for feedback to the Enc module, I however scaled the encoder output in the drive so that there was still one Index per rev.
« Reply #22 on: January 08, 2015, 06:23:28 PM »
HOWEVER I scaled the encoder output in the drive so thatthere was still one index per rev.
Is that not the solution? But how do you scale that up?
« Reply #23 on: January 08, 2015, 06:25:12 PM »
ups, error of me> servomotor
I use a rotary engine with a freq regulator
« Reply #24 on: January 08, 2015, 06:25:58 PM »
Only if you have a servo motor and drive for the spindle and only if the drive is capable of dividing buffered encoder outputs.
« Reply #25 on: January 08, 2015, 06:30:20 PM »
@ Hood,
Indeed, in a servomotor, but I was wrong
The CS LAB encoder which only need to thread? I would that encoder mechanical / pneumatic can switch in and out so that it does not work at + 6000 rpm.
So then I could run up to 10000 rpm, and threading with an enabled encoder.
« Reply #26 on: January 08, 2015, 06:32:45 PM »
The other issue would be when using G95, as is normal in lathe work. You would not get a spindle reading and thus your feed per rev would be incorrect.
« Reply #27 on: January 08, 2015, 06:37:18 PM »
@ Hood,
I will assemble the 6K encoder until I found a full 10K rpm encoder or someone can help me ...
« Reply #28 on: January 08, 2015, 06:38:57 PM »
Why not ask about the one I linked to?
It is 10,000rpm.
« Reply #29 on: January 08, 2015, 06:42:15 PM »
@ Hood,
sorry I do not understand you now
So you have an encoder already linked to a 10K rpm spindle?
Sorry for my bad english> google translate
