Hello Guest it is October 22, 2026, 06:22:13 PM
Author Topic: so the ess and 4 work?  (Read 8135 times)
Offline nobby
  •  154 154
« on: January 02, 2015, 06:05:32 PM »
great,
what is foxing me is there doesn't seem to be a pin out step and dir +/- diagram for the ess, does that mean I simply 'have' to use
http://www.aquickcnc.com/store/3-axis-unipolar-cnc-controller/
does that also mean that the limit switches are on the controller and not the ess, so its impossible without, not knocking it am just unfamiliar with it
I 'suppose' I do like the fact that its all together on the one board with a single power input for motors
are the chips similar to a tb6600?
does it want a 5v feed and the motor feed @ 36v
are the connectors to the right for limit switches
why then is it not bundled with the ess?
I don't need spindle controll or anything bar limits
are they making a single output 36 volt 10 amp psu - ar a psu that has both 5v and 36 v capability
hmmm
I have loads of server  5v psu's - the little ones, and loads of fans 5v
so I suppose all you need is the ess, that driver board a little 5v power unit and a 36v 10 psu in the box = box can be ereal small = like that.
also whilst on, I take it a cat5 cable simply can't supply the 5v for it and the limit switches?
« Last Edit: January 02, 2015, 06:12:27 PM by nobby »
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: so the ess and 4 work?
« Reply #1 on: January 03, 2015, 08:06:30 AM »
You plug a LPH26toDB25 cable into the SmoothStepper and you have a DB25, a.k.a. parallel port, connector with the same pin out as a parallel port.  The tb6600 based stepper drives really do not work well. I have had a lot of customers replace them with G540's and were shocked by how much better their machine ran. If you want to talk to a supplier that knows something about the ESS and how it works give me a call or drop me an email.
Happy machining , Jeff Birt
« Reply #2 on: January 06, 2015, 07:59:11 AM »
If this question is about whether ESS and Mach4 work well together: Yes, they do.
