Hello Guest it is October 23, 2026, 07:24:57 PM
Author Topic: gecko drive high amperage pin outs  (Read 8330 times)
Offline comet
  •  338 338
« on: December 24, 2014, 06:11:43 AM »
 im having an issue with the gecko 320x motor and supply connector, after a number of hours use mainly with the larger z motor the pin connector fails, ive heard of people soldering directly to the pins but im not so keen on that idea. has anybody out there found a solution?
regards Tony
Re: gecko drive high amperage pin outs
« Reply #1 on: December 26, 2014, 07:51:08 PM »
Contact Gecko and discuss the problem... they are good to deal with.
Offline comet
  •  338 338
« Reply #2 on: December 27, 2014, 05:39:32 AM »
its ok i just used the brass terminal connectors out of a small choc block (terminal strip) then super glued them together with plastic insulators between each other cut from an old credit card, works a treat !!
