Hello Guest it is November 22, 2026, 05:09:04 PM
Author Topic: What is the latest Mach3 ver. known to have probing working?  (Read 21662 times)
Re: What is the latest Mach3 ver. known to have probing working?
« Reply #10 on: December 22, 2014, 07:49:30 AM »
Well you KNOW how long it is correct ? Otherwise you will never be able to fill OUT the DROs for Yend.  It will NOT hurt to trim the data if you overrun the length while probing. OR if you parse the screw data you can trim it to length there.
IF you are doing an index of the screw then probe it will still catch all the data for the total length of the screw reguardless of the pitch variations you just have to plan for it in the sub program.
Just a thought, (;-) TP
« Reply #11 on: December 22, 2014, 08:02:04 AM »
ARE you trying to do this as a TURN application or a MILL application ??  Are you probing the screw itself  OR probing the table motion ?? Are you probing the top edge of the screww OR the side of the flank ?
It all depends, (;-) TP
« Reply #12 on: December 22, 2014, 08:57:05 AM »
Hi Terry,
Again the screw is the workpiece. It is mounted between centres on a lathe and the probing is of the side of the flank.
