Hello Guest it is November 22, 2026, 04:58:32 PM
Author Topic: Feed hold circle  (Read 8222 times)
Feed hold circle
« on: December 19, 2014, 08:09:21 AM »
HI all.  Running a laser with Mach3.  Yesterday I was cutting a PCB and hit feed hold to check something with the laser.  Mach3 stopped as it should, I did my checks and then hit Start.  As soon as I hit start, Mach3 reversed, then did a big circle on the PCB, circling back to the starting point then continued on as normal.  Needless to say, a ton of money went down the drain.
I've used Feed Hold before with no issues.  Do I need to restart, reboot each time I use Mach3?  Any idea?
Thanks,  Pete
Re: Feed hold circle
« Reply #1 on: December 22, 2014, 11:47:29 AM »
That did the same to me I was using the mill a circle pocket to check my servos and hit feed hold and when I restarted it  the tool path went  in reverse.
I hit feed hold again and it started up in the right direction.
Sorry I didn't answer your question but your not the only person who seen this.
