Hello Guest it is October 24, 2026, 06:13:37 PM
Author Topic: Howto connect ENC module - IPS / M3 turn ? No RPM readouts  (Read 34016 times)
Re: Howto connect ENC module - IPS / M3 turn ? No RPM readouts
« Reply #10 on: December 16, 2014, 08:04:20 AM »
Oh, great on the 5V, as the encoder works.
I wont worry about it then.
Yes, I have the spindle setup in the plugin.
The spindle works perfectly re: fwd and back .. its just that I dont get an rpm readout.
In encoder module, the position and angle change between position o, angle 0.0 and position -1/angle 360.
I remember that threading needs the RPM readout to work.
Do you know if the ENC is on another port and thats the signal I should feed to mach for the index signal ?
Or is it that the ENC based threading may work even if the RPM readout does not.
ENC fw is 1.02
MPG fw is 1.10
CSMIO fw is 2.500 / FPGA 2.50 (October 24/2014).
« Reply #11 on: December 16, 2014, 10:01:40 AM »
Attach your XML and I will take a look.
« Reply #12 on: December 16, 2014, 11:18:47 AM »
Thanks Hood !
Here is the file CSLathe.1.xml.
« Reply #13 on: December 16, 2014, 03:14:21 PM »
Go into ports and pins and disable the Index, see if that helps, you dont need that set and it may well be conflicting.
« Reply #14 on: December 17, 2014, 06:33:23 AM »
Removing index got rpm readout working !
