Hello Guest it is November 01, 2026, 10:12:42 AM
Author Topic: Lazy Cam not sending pass depth to G-code  (Read 9117 times)
Jeff
« on: April 04, 2007, 08:08:55 AM »
Lets say I change a layer to a cut depth of 5 and the depth per pass to 1 and send it to G-Code, it will cut 1 pass at a depth of 1 and stop. I'm new to this but I can see in Lazy Cam the 5 cuts when I rotate the part. For some reason it doesn't finish cutting to the depth of 5. Can anyone tell me what I'm doing wrong.
Jeff
Re: Lazy Cam not sending pass depth to G-code
« Reply #1 on: April 04, 2007, 09:06:09 PM »
hmmmmm I think it is a plasma setting that you have... could you check your post options?
Brian
www.newfangledsolutions.com
www.machsupport.com
