Hello Guest it is October 25, 2026, 12:47:12 PM
Author Topic: Rotaryaxis reference  (Read 10856 times)
« on: December 06, 2014, 10:32:21 AM »
Hi all,
to reference Z, X, Y and A I use a macro (see below).
The A is a rotational axis, sothe refrence switch can be active when starting the refrence run.
I check it with "If getoemled(839) Then".
If active, then I would like to rotate the axis by some degrees, and do the refrence run after that.
Simple so far.
But often it doesn't work.
I think I have towait until the move is done with the famous IsMoving function.
See "'*" in the macro.
If the IsMoving is in the macro, Mach3 hangs.
What can be the reason, and how to avoid it?
Greetings,
Gregor
'ref Z first
DoOEMButton(1024)
'ref XY
RefCombination(3)
'check for active switch
code("G91 G0 A-14")
'*While IsMoving()
'*Wend
End If
DoOEMButton(1025)
'code("G90 G53 G0 A47")
Offline mc
  •  384 384
Re: Rotaryaxis reference
« Reply #1 on: December 06, 2014, 02:51:55 PM »
Macros are pretty slow to respond to inputs (should be a 10Hz refresh rate), so are not really suited for homing routines or anything that requires critical timing.
The homing routines work far quicker, however I have no idea how you implement them for an A-xis.
« Reply #2 on: December 06, 2014, 03:44:49 PM »
Give this a try.
' Macro for Homing Machine
Dobutton(24)   ' Reference Z
While Ismoving()
Sleep(10)
Wend
DoButton(22)   'Reference X
While Ismoving()
Sleep(10)
Wend
DoButton(23)   'Reference Y
While Ismoving()
Sleep(10)
Wend
If GetLED(39) Then    'Check for A home LED IF so then
   Code"G91"
   Code"G0 A-45"
   Code"G90"
   While Ismoving()
   Sleep(10)
   Wend
   DoButton(25)
   While Ismoving()
   Sleep(10)
   Wend
Else         'Other wise reference A
   DoButton(25)
   While Ismoving()
   Sleep(10)
   Wend
End If
End
« Reply #3 on: December 06, 2014, 04:33:53 PM »
> Give this a try.
Wow, works exactly as expected and reliable.
Even with the positioning after A reference (code("G90 G53 G0 A47")).
Any explanation why RefCombination does not work?
Not so important, just curious.
Thank you,
Gregor
« Reply #4 on: December 06, 2014, 06:16:20 PM »
It never really did work dependably (;-)  The long hand versions of most functions always worked well in the past.
