Hello Guest it is November 13, 2026, 09:47:56 AM
Author Topic: Dual head offsets.  (Read 51197 times)
Re: Dual head offsets.
« Reply #30 on: December 13, 2014, 04:30:51 AM »
Still not sure what your trying to do as your using the same Z move to do two things? Wont one of the heads run into something while they are both going up and down at the same time?
but as far as your numbers I would think your mixing imperial fixture offsets with metric gcode movements
150" * 25.4 = 3810mm and 50" * 25.4 = 1270mm ( that's why your seeing the huge movements)
you might want to make sure you setup units are in metric or use the equivalent value (just some more math).
Code: [Select]
N1 G17 G21
N3 T1 M6
G90
G54
G0 Z6.
S4851 M3
X200. Y0. M8
N6 G81 Z-10.866 F1000. R2.5
N7 G80
M9
G55
X200. Y0.
G1 Z-10.866 F1000.
G0 Z6.
G54
X200 Y0
m30
I think the same thing, my units on the mach is "MM", and i tried to convert to imperial (X6 Y2 Z0) and the mach do the same thing :/
BTW, The second head is activated by pneumatic actuator and another guide, that's why i dont need to use Z offsets.
« Last Edit: December 13, 2014, 04:36:26 AM by Glaucius »
« Reply #31 on: December 13, 2014, 04:35:07 AM »
Set your G55 to X100 Y50 and save fixture
Move to the Point of Origin X0Y0 on your material. then Zero the xy axis(that will set the g54 to 0,0)  the example just drills 1 hole then offsets the head and drills another hole in the same spot to prove the offsetting works correctly.
N3 T1 M6
G54
G00 X200. Y0. S4851 M3
N5 Z6.
N6 G81 X200. Y0. Z-10.866 F1000. R2.5
N7 G80
(Switch to G55 to offset to the 2nd head)
G55
N9 G81 X200. Y0. Z-10.866 F1000. R2.5
N7 G80
G54 ( go back to the original fixture offset)
G0 X0 Y0  (Go back to the original Point of origin)
M5 M9
M30
NOW do not get confused by what you see in the toolpath as it does NOT exactly show what the machine is going to do. Just follow the machine tool as it does the job IT will be correct.
Thanks!....I will try that!
I wanna make "hole and screw" path because the OSB panel is loose on the table, so the screw will secure the panel...but i will test the 2 scenarios ;)
« Reply #32 on: December 16, 2014, 12:55:02 PM »
Is there a pic of this machine?
« Reply #33 on: December 16, 2014, 01:42:11 PM »
I have a few pics, i just have to pass to my desktop, my smartphone is on repair so i can't pass the pics directly :/
When i get the pics i post here.
