Hello Guest it is October 26, 2026, 05:09:37 PM
Author Topic: misalignment of Y axiz in plasma cutting table  (Read 11260 times)
« on: December 04, 2014, 12:50:06 PM »
Postby LEO ยป Thu Dec 04, 2014 2:22 pm
HELLO GUYS
A few months ago finalize my project in a plasma cutting table 5x10 ft, my compressor capacity was very small so I could only make continuous cuts of 3 minutes Now I have a compressor 80 gallon thing is very different there has been a great problem after 7 or 8 minutes of continuous cutting the y axis misalignment around 3/8" I tightened the screws on the gears and racks all is well fixed , I reviewed mach3 settings and everything is the same in the two motors that move the Y axis someone something happened thank you very much for your support
add pics
Re: misalignment of Y axiz in plasma cutting table
« Reply #1 on: December 05, 2014, 01:51:12 AM »
Possibly an axis is binding causing you to lose steps or it may just be you have your axes tuned too fast, try reducing the Velocity in Motor tuning.
« Reply #2 on: December 05, 2014, 10:39:51 AM »
HELLO hood;
you are very kind to take time to help
 my cnc kit is a bladeruner of candcnc.com the current configuration of the motor is:
X AND Y: STEPS PER INCH 979.42, VELOCITY 500, ACCELERATION 35
Z: STEPS PER INCH 10,000, VELOCITY 100, ACCELERATION 35
can you give me an advice about the changes that you think suitable for this configuration?
« Last Edit: December 05, 2014, 10:41:28 AM by ganadero »
« Reply #3 on: December 06, 2014, 06:23:05 AM »
Each machine will be different and when using steppers it is just a case of trial and error to find the correct velocity and acceleration.
« Reply #4 on: December 06, 2014, 08:43:37 AM »
tanks very much HOOD
this week will try to solve that problem, because it is impossible to work with such failure
« Reply #5 on: December 15, 2014, 12:18:19 PM »
news about my failure friends;
I've noticed that when I do .tap code in the computer workshop, causes me this fault and when performed on my home computer all going great some friends could tell me i know the reason i use SHEETCAM
tanks very much my friends
