Hello
Guest
it is
November 13, 2026, 12:16:45 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach 3 troubles
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach 3 troubles (Read 11224 times)
Brookie
5
mach 3 troubles
on:
December 03, 2014, 03:38:25 PM »
I have a Shopmaster Elderado. As once in the past. my machine refused any commands. After Hood looked over the XML. He said mach3 was corrupt . to uninstall it and download again. It worked quite well for a longtime. It has stopped again so I deleted the software, then scanned the computer twice and downloaded mach3 . It still refuses all commands..
I had ran the first two operations of his G-Code but had to quit a week waiting on a loose tap holder to arrive
Help Please
attached is the xml and the last G code I ran
Logged
Fastest1
920
Houston, TX
Re: mach 3 troubles
Reply #1 on:
December 04, 2014, 12:48:03 PM »
Have you physically shut everything down? Disconnected the PP cable while powered down, then reconnect everything? Do you get any axis movement via the jog or hot keys? Steppers resist or get warm?
Logged
johnny
90
Re: mach 3 troubles
Reply #2 on:
December 04, 2014, 02:02:45 PM »
I have disconnected all plugs and reconnected these. I did gain movement to the X Y Z axis but no spindle or speed control. I am attaching a wire dia. What wires control spendle movement and speed control? ?
Logged
Fastest1
920
Houston, TX
Re: mach 3 troubles
Reply #3 on:
December 04, 2014, 02:26:24 PM »
Pins 7,8 & 9 on your BOB control the VFD, Pin 5 & 6 are used if you have directional control (fwd/rev) in Mach. Nothing in your wiring has changed to make you suspicious of it, is there?
Logged
Fastest1
920
Houston, TX
Re: mach 3 troubles
Reply #4 on:
December 04, 2014, 02:28:13 PM »
I would go into the Mach screen first and verify how the spindle is controlled and that all settings are correct before I even contemplated a wiring change.
Logged
Brookie
5
Re: mach 3 troubles
Reply #5 on:
December 04, 2014, 03:38:15 PM »
wasnt thinking of wire change..just a power check in and out
Logged
Print
Pages:
1
Go Up
« previous
next »
