Hello Guest it is October 20, 2026, 03:02:09 PM
Author Topic: Slaved X and A Axis Problem  (Read 20525 times)
Re: Slaved X and A Axis Problem
« Reply #10 on: November 22, 2014, 06:58:48 AM »
Why just use 1 motor? If you have an easy way to add a belt reduction, then do a 1:2 reduction, but still use both slaved motors.
« Reply #11 on: November 30, 2014, 05:20:29 PM »
Progress... I put a belt drive on each of the X and A axis to reduce the motor speed in half. I made sure there was no mechanical slippage by filing a flat on the shaft of the motor and ball screw shafts.
I ran a simple test pattern to put a 1/4 inch hole in the corners of a 10x10 square and I have 1/4 inch dowel pins for measurement. No matter how many times I run it, the A axis is ALWAYS .015 shorter
than the X axis. I retightened all the pulleys but to no avail. Then I switched the two axis wires on the Gecko G540 to see if was the driver. The same side was still short......
I have run out of ideas to try....Could the motor/motors be bad???
Any help would be greatly appreciated.
