Hello Guest it is November 13, 2026, 12:00:21 PM
Author Topic: Autozero and Coordinate issues are loading G-Code  (Read 36682 times)
Re: Autozero and Coordinate issues are loading G-Code
« Reply #20 on: November 08, 2014, 10:28:59 AM »
You should try to avoid mixing units at all costs. While you may get away with it most of the time, sooner or later something will go wrong.
Offline ZASto
  •  434 434
« Reply #21 on: November 09, 2014, 10:25:46 AM »
Code from Blue Screen b Big Tex (with minor modifications by me):
Code: [Select]
Sub Main()
'made it a sub, so you can return on "show stopper" errors
'UPDATED TOOL CHANGE ZERO SETUP SCRIPT
'Option Explicit
'Written by Big-Tex December 29 2010
'Modified by Poppa Bear, added Greolt's and Arbo's changes 08Dec2010
Dim xjobcoord, yjobcoord, zjobcoord, xmachcoord, ymachcoord, zmachcoord
Dim ZNew, ZPlate, Zplatetomaterial,PlateOffset, ZMaterialmachcoord, Zplatejobcoord
Dim xprobeloc, yprobeloc,xtoprobe, ytoprobe
Dim FirstProbeDist, FirstRetractDist, SecProbeDist
Dim CurrentFeed
Dim CurrentAbsInc
xjobcoord = GetDRO(0) 'get current job coordinate for X
yjobcoord = GetDRO(1) 'get current job coordinate for Y
zjobcoord = GetDRO(2) 'get current job coordinate for Z
xmachcoord = GetOemDRO(83) 'get current machine coordinate for X
ymachcoord = GetOemDRO(84) 'get current machine coordinate for y
zmachcoord = GetOemDRO(85) 'get current machine coordinate for z
xprobeloc = GetUserDRO(1100) 'get x machine coord of fixed plate
yprobeloc = GetUserDRO(1101) 'get y machine coord of fixed plate
xtoprobe = (xprobeloc - xmachcoord + xjobcoord) 'calc x move to fixed probe
ytoprobe = (yprobeloc - ymachcoord + yjobcoord) 'calc y move to fixed probe
CurrentFeed = GetOemDro(818) 'get current feed rate
PlateOffset = GetUserDRO(1151) 'get plate offset DRO
Zplatetomaterial = GetUserDRO(1102) 'get calculated material offset from somewhere else?
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
'//////// the block below will set all your reusable vars depending on Inch or mm.
'//////// this sets the vars so you only need ONE large block of probing code.
If GetOEMLED(801) Then 'ON = English Measure INCH
FirstProbeDist = 6.0 'first probe travel
FirstRetractDist = 0.1 'first probe retract travel
SecProbeDist = 0.25 'second probe travel
FirstProbeFeed = 12 'First Probe Feed Speed
SecondProbeFeed = 2 'Second Probe Feed Speed
Zretract = -0.5 'Z retract
Else 'OFF = Metric Measure MM
FirstProbeDist = 150.0 'first probe travel
FirstRetractDist = 3.0 'first probe retract travel
SecProbeDist = 6.0 'second probe travel
FirstProbeFeed = 300 'First Probe Feed Speed
SecondProbeFeed = 50 'Second Probe Feed Speed
Zretract = -12 'Z retract
End If
'//////// Error Condition checking code
If GetOemLED(16)<>0 Then 'Checks for machine coordinates
Code "(Please change to working coordinates)"
Exit Sub 'ERROR! exit the macro
End If
If GetOemLED(825)<>0 Then
Code "(Z-Plate Grounded Check connection and try again)"
End If
'//////// Start Probing Code, Probe In -Z direction.FIXED PLATE
'//////// The vars will be Inch or Metric from above if/else statment
Code "G0 X" & xtoprobe & " Y" & ytoprobe 'move to fixed plate location
Code "F" & FirstProbeFeed 'slow down feedrate to 12 ipm, or 300 mmpm
Zplate = (GetDro(2) - FirstProbeDist) 'probe move to z - 6", or 150mm
Code "G90 G31Z" & Zplate 'FIRST Probe Operation!
While IsMoving()
Wend
Zplate = GetVar(2002) 'read the touch point
Code "G1 Z" & (Zplate + FirstRetractDist) 'retract above hit point +0.1" or +3mm
While IsMoving()
Wend
Code "F" & SecondProbeFeed 'slow down feedrate to 2 ipm, or 50 mmpm
Zplate = (GetDro(2)- SecProbeDist) 'probe move to current z - 0.25", or -6.0mm
Code "G90 G31Z" & Zplate 'SECOND Probe Operation!
While IsMoving()
Wend
Call SetDRO(2,Zplatetomaterial) 'this sets Z DRO to calculated material offset
Sleep(250) 'pause for Dro to update.
Code "G53 G0 Z" & Zretract
While IsMoving () 'wait for probe move to finish retracting
Wend
Code "G0 X" & xjobcoord & "Y" & yjobcoord 'returns to the previous X Y job location
While IsMoving()
Wend
Code "F" & CurrentFeed 'returns to prior feed rate
'//////// End Probing Code,
Code "(Z axis is now zeroed in English Units)" 'puts this message in the status bar
Code "(Z axis is now zeroed in Metric Units)" 'puts this message in the status bar
End If
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
Code DoButton(0) 'Cycle Start
End Sub
I've also modified other button scripts to deal properly with Inch and mm measurements according to units to which the Mach3 is set (OEMLED 801)
« Last Edit: November 09, 2014, 10:28:42 AM by ZASto »
My personality is who I am.
