Hello
Guest
it is
October 15, 2026, 05:50:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Upgraded too Mach3 R3.043.066
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Upgraded too Mach3 R3.043.066 (Read 9127 times)
harrykaw
4
on:
October 30, 2014, 11:27:41 AM »
After I upgraded to mach3 R3.043.66 I ran a gcode (from Vectric cut 2d ver 1.5) for cutting a 3inch circle. The circle came out as an oval approx y=3in and x= 2.25 in. The display window in mach3 shows it as a perfect circle!
The really strange thing is when I run a gcode file for 3in circle from mach3 wizard; it comes out as a perfect 3 in circle.
The only difference in gcode is, cut2d uses 4 arcs to cut the circle and mach uses a circle!
Any Thoughts?
handsmfg
65
Re: Upgraded too Mach3 R3.043.066
Reply #1 on:
October 30, 2014, 12:55:46 PM »
Do you have IJ Mode set right in General Logic Configuration. I can't remember whether you need absolute or incremental.
Eric
harrykaw
4
Reply #2 on:
October 31, 2014, 11:25:55 AM »
Eric
It is set too IJ,I tryed Absolute ,but the program reset it to IJ ,even thought I save it.
I'm Includeing the files this time ,maybe some one would run them on there machine and let me know there results
Thanks ,Harrykaw
Print
Pages:
1
Go Up
« previous
next »
