Hello Guest it is November 13, 2026, 05:18:28 PM
Author Topic: Pokeys 57E Need help getting started  (Read 43497 times)
Re: Pokeys 57E Need help getting started
« Reply #10 on: November 02, 2014, 09:34:12 AM »
Hi markus,
how does your setting (electrical) look like?
What drivers are you using?
How do I install transistor switches?
Can you post a picture?
Yeah maybe you are right, I tried it just with the x-axis, cause there I dont need the pullup resistors...
I'll try it tomorrow with the Y and Z axis...
I found out that Pokeys is installing stuff all over my pc... tried to delete everything befor I installed the latest firmware again...
Actually I dont need to Install Mach3 everytime, cause at first the motors should move with the pokeys SW, right?
Lukas
« Reply #11 on: November 03, 2014, 12:32:36 AM »
Dear Lukas,
attached you will find my layout.
Kind regards,
Markus
PS.: To all: I do not guarantee for this circuit. Everyone is responsible for himself to check and - if necessary - to adopt it it before it is used within an electrical circuit.
« Reply #12 on: November 05, 2014, 12:31:07 PM »
Hi Markus,
thanks for your help.
IT WORKS!!!!!!!!!!!!!
I used the 3,3V output instead of the 5V and connected it to PUL+ (+5V) and DIR+(+5V).
Then PUL- to Pokeys [PIN46 ,..............PIN 48 & 49 with 470 Ohm resistor]
DIR- to 38;39;40 on Pokeys.
Suddendly it worked.
When I used 3.1.38 Firmware the Motors started althought the Emergency-switch was activated while starting Mach 3.
I downgraded to 3.1.17 and everything works fine...
The Driver seems to be okay with 3,3 V instead of the discribed 5V.
Took me all my nervs but now I can go for my mechanical setup.
Cheers Lukas
