Hello Guest it is November 22, 2026, 09:17:49 PM
Author Topic: Spindle stops rotating durring program run  (Read 10749 times)
« on: October 19, 2014, 05:01:42 PM »
I have had the Spindle stop rotating durring program run twice. I can restart the spindle, but what would cause it to shut off while making a very light cut? I ran the same program all yesterday with no such problem. Any ideas are appreciated. My machine is a SYIL X3 conversion using Mach3.
Re: Spindle stops rotating durring program run
« Reply #1 on: October 22, 2014, 01:16:29 AM »
I have noticed the spindle stops when I run it at about 1900 to 2100 RPM. It will restart immediately, but will shut down after a couple minutes. If I run the spindle at about 1500 RPM, it will run all day. Is there some overload sensor that shuts the spindle off if it detects vibration or strain? Is there a control board inside the head that may be flakey?
  •  9,378 9,378
« Reply #2 on: October 22, 2014, 01:58:10 AM »
From memory the X3 spindle controller has an overload sensor which does shut it down - perhaps, in your case, it is being a little over sensitive ?
« Reply #3 on: October 22, 2014, 02:00:25 AM »
Is there any adjustment for it? Can it be replaced? If so, where would I locate one?
