Hello Guest it is September 09, 2026, 06:51:02 AM
Author Topic: 5vdc power supply  (Read 14620 times)
Offline Glenn
  •  129 129
5vdc power supply
« on: March 30, 2007, 02:37:28 PM »
Hi all,
I got a 5vdc psu to run my gecko 201's, step and direction signals, but unsure where to connect them up at.
I believe the positive goes on the common screw terminal, but, where would I connect the ground contact?
I have had the mach 3 run one axis ok, but the other one on my lathe seems to need motion from the other
axis (some weird voltage- sharing happening,maybe) to complete the step-direction circuit before it will move.
I thought the step and direction would run off of the 5vdc coming out of the printer port, but I just can't make this happen! :-[
Any suggestions would really improve the current situation I'm in!
Glenn
P.S.  I'm using a 35vdc psu unit to run 2 steppers..seems like plenty of power on that end of the issue.
Don't assume anything.....it'll make a Manager out of U and Me!
Re: 5vdc power supply
« Reply #1 on: March 30, 2007, 03:44:52 PM »
what do you have for a breakout board?
www.newfangledsolutions.com
www.machsupport.com
Offline Glenn
  •  129 129
« Reply #2 on: March 30, 2007, 09:07:34 PM »
Hi Brian,
I use a cnc DB25 breakout board for stepper motor drivers.
It uses only the first 17 pins as normal and the 18th pin is ground. By the way,
should I be using that ground pin?..It is unused right now.
I only use pins:  2+3+7(step,direction,common) x axis
                       4+5+8(step, direction,common)z axis
Glenn
Offline klmark
  •  107 107
« Reply #3 on: March 31, 2007, 08:52:49 AM »
5 volt dc ground should be connected to the PC ground had some problems lattle got help from gecko at is what day told me and it works
Offline Glenn
  •  129 129
« Reply #4 on: March 31, 2007, 08:58:26 AM »
Hey Markkl,
Now I'll show you my ignorance,  ;D could you please tell me where the PC ground is?
I'm being cautious to prevent ANY chance of ruining my components.
Glenn
Offline klmark
  •  107 107
« Reply #5 on: March 31, 2007, 09:53:01 AM »
I used the printer port ground pin and the gecko guy told me I could use the game port to supply the 5 volts to the drivers another ground to the pc take a meter put one end to the 5 volt ground and the other end any were on the PC were you can fasten a ground if your meter reads a dead short that is a good place for the ground
Offline Glenn
  •  129 129
« Reply #6 on: March 31, 2007, 02:18:33 PM »
Markkl,
 Thanks for the much needed guidance!
I will attempt these connections and see if she floats!
Cheers!
Glenn
Offline Glenn
  •  129 129
« Reply #7 on: March 31, 2007, 08:28:04 PM »
Just a note to let you know that sometimes aren't as they seem..
It wasn't a grounding problem,but rather the breakout board (thanks Brian),the pins all check out with a continuity tester, but still the signals got all twisted before reaching the geckos.
 Now the pinout is: 2+3+7 (step,direction,common) x axis
                    and  16+5+8(step,direction,common) z axis!
It works! I still don't know why, but I am not changing it.
Thanks to all you guys,Markkl,Brian, Hood and Brett!
Glenn :)
