Hello Guest it is November 13, 2026, 05:56:51 PM
Author Topic: Firmware problems 57E  (Read 37667 times)
Offline NeoTO
  •  504 504
    • PoLabs
Re: Firmware problems 57E
« Reply #10 on: February 07, 2018, 11:19:23 PM »
Hi, Azalin
What is the reason for requiring 4.1.2 firmware? The older firmware versions are available to OEMs that have implemented functions specific to a certain firmware.
The latest PoKeys firmware should be the best choice both in reliability and feature set.
Matevž, PoLabs
Offline Azalin
  •  191 191
« Reply #11 on: February 08, 2018, 01:16:34 AM »
Hi Matevž,
Lathe encoder doesn't work with the latest firmware. In the PoKeys diagnostigs screen I can see the pins 8, 12, 13 are flashing when I spin the spindle with my hand but Mach4 doesn't receive an RPM value.
It was working perfect with the old firmware. I downgraded the firmware to v4.2.39 and lathe encoder works now. Card is 57E by the way.
Is this a bug of 4.3.9a?
