Hello Guest it is November 10, 2026, 01:57:12 AM
Author Topic: Ref All Axes - All at same time?  (Read 25328 times)
Re: Ref All Axes - All at same time?
« Reply #10 on: October 19, 2014, 05:02:55 PM »
Post your homing code.
« Reply #11 on: October 19, 2014, 07:11:50 PM »
RefCombination(7)
While IsMoving()
Wend
SetParam("XRefPer", GetParam("XRefPer")/10)
SetParam("YRefPer", GetParam("YRefPer")/10)
SetParam("ZRefPer", GetParam("ZRefPer")/10)
RefCombination(7)
While IsMoving()
Wend
SetParam("XRefPer", GetParam("XRefPer")*10)
SetParam("YRefPer", GetParam("YRefPer")*10)
SetParam("ZRefPer", GetParam("ZRefPer")*10)
« Reply #12 on: October 19, 2014, 07:16:20 PM »
Are you seeing a limit switch error?
Set a debounce of about 5000 and see if it works. Sounds like noise is triggering the switches while backing off.
« Reply #13 on: October 19, 2014, 09:03:58 PM »
Debounce in Mach settings or in the homing code?  Can I put a pause command after the 1st Wend in the homing code I posted?
« Reply #14 on: October 19, 2014, 09:08:02 PM »
General Config.
Offline TPS
  •  2,627 2,627
« Reply #15 on: October 20, 2014, 02:55:27 AM »
try this code, had a simular thing couple of weeks ago:
RefCombination(7)
Sleep(300)
While ((GetOemLed(807) = true) Or (GetOemLed(808) = true) Or (GetOemLed(809) = true))
   Sleep(50)
Wend
RefCombination(7)
Sleep(300)
   Sleep(50)
Wend
Thomas
« Reply #16 on: October 24, 2014, 12:40:32 PM »
It sort of worked. The parameters would get out of sync so on subsequent homing it would sometimes start off on the lower federate.  Instead of using getparam, I just typed in an actual value that suited my needs.   Thanks guys.
