Hello Guest it is November 20, 2026, 11:13:44 PM
Author Topic: stl or mpc conversion to Gcode  (Read 10216 times)
« on: September 25, 2014, 04:42:53 PM »
How to I convert stl or mpc file generated by CarveWright Designer program to Gcode using Mach3 on my DIY CNC machine?
Re: stl or mpc conversion to Gcode
« Reply #1 on: September 26, 2014, 05:39:13 AM »
Mach 3 dosen't convert files for G code. . You need software that can use / import stl files and allow for manipulation of the stl file to create G code
in a format which is used by Mach. Not familar with CarveWright, but, if you go to their site you will find info on using it. See if there is a post processor available for Mach3 from CarveWright.
