Hello Guest it is September 06, 2026, 02:04:14 AM
Author Topic: Gage Block Height increments oneself  (Read 7785 times)
« on: September 24, 2014, 03:27:38 AM »
Hallo
Gage Block Height (in Offset Screen top/left) increments oneself.
The same value can i see in Digitizing Wizard "Width X" !
In Digitizing Wizard i can not enter "Width Y" and "Z travel" the values are overwritten onself.
In other respects my machine works very well since years.
Now i will use the Digitizing Wizard with my new XYZ probe.
I use Version R3.042.038
Could everyone help or give me a idea to isolate the problem ?
best regards :)
 fridolin
Re: Gage Block Height increments oneself
« Reply #1 on: September 25, 2014, 02:36:35 AM »
Ok ... i found the problem myself. 8)
I have conflicting OEM variables used in the range 1001 to 1009.
My variables monitors the micropump macro and  modbus inputs via brains.
Gage Block Height use a OEM Variable 1001 and Digitizing Wizard use OEM variables 1002 to 1007 !
This isue is not documented in the manuals. ::)
best regards
 fridolin
