Hello
Guest
it is
November 07, 2026, 04:39:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach3 under Vista
newbie with mach 3 need some help setting up.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: newbie with mach 3 need some help setting up. (Read 30026 times)
tonywads
41
Re: newbie with mach 3 need some help setting up.
Reply #10 on:
November 16, 2014, 11:22:30 PM »
when you brought your machines you should have a a4 sheet with all the motor settings and basic setup setting pin and ports motor tuning ect.. then you need to setup mach 3 to use mm and not the default inches
Print
Pages:
1
2
Go Up
« previous
next »
