Hello Guest it is November 07, 2026, 04:39:52 PM
Author Topic: newbie with mach 3 need some help setting up.  (Read 30025 times)
Re: newbie with mach 3 need some help setting up.
« Reply #10 on: November 16, 2014, 11:22:30 PM »
when you brought your machines you should have a a4 sheet with all the motor settings and basic setup setting pin and ports motor tuning ect.. then you need to setup mach 3 to use mm and not the default inches
