Hello Guest it is September 23, 2026, 07:57:17 AM
Author Topic: spindel speed disc  (Read 30878 times)
spindel speed disc
« on: November 08, 2005, 10:52:48 AM »
How and what do I make a spidel disk out of ror a PWM. I have a PWM sensor from cnc4pc.
Matt Holtzclaw
Re: spindel speed disc
« Reply #1 on: November 08, 2005, 07:11:09 PM »
Matt you can make a disk that uses a Prox or a bit of reflective tape.  The Reflective tape is a good way to go because you have such a small amount of work to do getting it hooked up! The one that I saw used was a Prox and a metal disk. This is a but better because you can put stuff all over the plate or the prox and it will keep working.
Hope that is a little help... If you can tell me more I will see what I can do about getting you more info.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
