Hello Guest it is November 01, 2026, 06:02:26 AM
Author Topic: Not getting the Uc100 pop up window when opening Mach3  (Read 8450 times)
« on: September 04, 2014, 07:39:53 PM »
I have the driver installed and see it connected under my unspecified devices window as working properly. Green light is lit but not the blue. Idk what im missing!?!?
Re: Not getting the Uc100 pop up window when opening Mach3
« Reply #1 on: September 05, 2014, 02:40:07 AM »
If I am understanding what you are meaning, then go to Function Config menu and choose Reset Device Select then restart Mach.
« Reply #2 on: September 05, 2014, 09:04:30 AM »
I believe I did try that without any success.  I will Def try that again once I get back home. If anything I may reinstall mach 3 and try it again.
