Hello
Guest
it is
November 26, 2026, 11:48:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach 3 rev2.031 works OK but mach 3 rev2.060 Feed rate problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach 3 rev2.031 works OK but mach 3 rev2.060 Feed rate problem (Read 11750 times)
NPC-Egypt
5
l'Egypte, le pays des pharaons
on:
March 27, 2007, 05:38:47 AM »
Hi all
This is my first post.
I use do make my PCBs with mach 3 rev2.031 and every thing was working fine.
today I switch to 060 but feeddrate was reducing gradually from 254mm/min to 50 mm/min (or 10"/min to 1.9"/min) after 5000 program lines.
then I reinstall mach 3 rev2.031 and every thing returns to normal again.
is there any explanation.
here I attach 2 nc pcb files one in inch and another in mm (same problem with both)
thanks
Logged
Brian Barker
3,860
Re: mach 3 rev2.031 works OK but mach 3 rev2.060 Feed rate problem
Reply #1 on:
March 27, 2007, 09:03:31 AM »
This is the first time I have heard that one... I will ask Art if he has seen any support on this.
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ART
1,703
Tough as soggy paper.
Reply #2 on:
March 27, 2007, 09:32:28 AM »
Hi:
Havent seen that before. Does the commanded feedrate DRO also lower?
Art
Logged
NPC-Egypt
5
Reply #3 on:
March 27, 2007, 01:30:35 PM »
Hi Art , Brian
thanks for your reply
commanded feedrate DRO (function 2018) is not changing
it is either 254mm/min (metric) or 10"/min (Imp.) all time.
it is (function 2013) that lower gradually with program lines until machine stop.
Regards
Joe
Logged
Print
Pages:
1
Go Up
« previous
next »
