Hello Guest it is November 01, 2026, 09:00:35 AM
Author Topic: tb6600 fried - what now?  (Read 23802 times)
Re: tb6600 fried - what now?
« Reply #10 on: August 29, 2014, 12:38:48 PM »
What kind of machine is this? What is the drive system(s).
Offline kiark
  •  12 12
« Reply #11 on: August 29, 2014, 12:58:11 PM »
it is a DIY eshapeoko i assembled. it is belt driven on the X and Y axis and uses a leadscrew on the Z axis
i found a NEMA23 Motor on the geckodrive site which is recommended for the gecko540
http://www.geckodrive.com/stepper-motors/g723-280-4.html
unfortunately if i do the maths again i get a higher needed voltage than the allowed 50v since the motors have 3.6mH
kiark
« Reply #12 on: August 29, 2014, 01:10:33 PM »
That formula is to get the maximum rpm out of the motor. With the direct belt drive, you don't need anywhere near the max rpm. I'd try your existing motors and see how they work before buying new ones.
If you do want to replace them, look at Automation technologies (Keling) if you want to save a few bucks.
Offline kiark
  •  12 12
« Reply #13 on: August 29, 2014, 01:13:15 PM »
ah i see! i was just worrying about frying something with the power source!
so thank u very much again for all the help!
kiark
