Hello Guest it is October 22, 2026, 11:49:09 PM
Author Topic: Embedding the "Mach MAD" for 4, into a screen set! Still got stuff to do!  (Read 19733 times)
Added Output edit controls to the OUTPUTS window.
where you push the "Pause Updates" toggle button, click in the cell you want to change (0 or 1), press enter. Then press the "Set Change" button, that will immediately turn on or off that output.
press press the toggle button again to un-pause the updates.
Scott
