Hello Guest it is October 20, 2026, 02:52:26 PM
Author Topic: A Get It Out Of The Way button???  (Read 34401 times)
Offline Davek0974
  •  2,606 2,606
Re: A Get It Out Of The Way button???
« Reply #10 on: August 11, 2014, 06:03:05 AM »
Files below,
many thanks
« Reply #11 on: August 11, 2014, 06:20:58 AM »
Which button do you have the code in?
« Reply #12 on: August 11, 2014, 06:22:33 AM »
Ok I see now, Park Gantry button.
You will have to alter it to a VB button in the screen designer. I think you have it as a code button and for that you can only have one line of code, so that is likely your problem.
Offline Davek0974
  •  2,606 2,606
« Reply #13 on: August 11, 2014, 06:32:59 AM »
Hmm, ok thanks.
I can't see how that's done in Machscreen, I must admit that that program is a difficult piece of work, for me at least. :(
I see no VB button feature at all, just "Button".
« Reply #14 on: August 11, 2014, 06:37:59 AM »
Double click your button and you will see similar to below, just choose the VB option. Once saved then go into Mach again then on Operator menu choose Edit Button Script. Your button will be flashing, click it and the editor will open, paste your code in then File and Save and then exit the editor.
Offline Davek0974
  •  2,606 2,606
« Reply #15 on: August 11, 2014, 06:48:11 AM »
Is that from MachScreen?
I can't double-click anything in my version, clicking just brings up a little box with the image name, button name etc in it.
No double-click option.
I have version 1.60
« Reply #16 on: August 11, 2014, 06:53:56 AM »
Its Screen4, I dont use MachScreen so dont know how to do it in that.
Offline Davek0974
  •  2,606 2,606
« Reply #17 on: August 11, 2014, 07:29:07 AM »
Excellent, downloaded, edited, working nicely now :)
Many thanks
Offline Davek0974
  •  2,606 2,606
« Reply #18 on: August 11, 2014, 07:55:13 AM »
One little thing, is there a way to get the button text on two lines in screen4??
The "Lines" box is greyed out.
« Reply #19 on: August 11, 2014, 08:10:01 AM »
If you are meaning the actual Text on the button then I dont think so. I always use Image buttons so can not be 100% sure though.
If it can be done in MachScreen then just open your screenset in it and alter.
