Hello
Guest
it is
September 18, 2026, 06:06:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach3 and G-Rex
GREX & MACH General (Possible stupid Questions)
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: GREX & MACH General (Possible stupid Questions) (Read 12947 times)
mhdale
130
Knowledge is the Treasure.
on:
March 17, 2007, 02:48:40 PM »
Hello All, I have finally taken some initiative and tried hooking up my GREX to see if it might address & fix some of my systems issues. I followed the instructions for setting up the GREx and most everything seems to have worked as it should have... I cannot get the GREX to respond to the test file as described in the easy setup guide from gecko, I have loaded the proper firmware and such I can PING my GREX but Mach says it cant find the grex... I had tried to create a new MACH installation for the grex but when I ran the latest update for mach3 it didnt update the directory I told it too... should I be using mach3 or quantum for testing the grex?
Thanks....
p.s. Is there the simpletons guide to setting up your grex?
Mike
mhdale
130
Re: GREX & MACH General (Possible stupid Questions)
Reply #1 on:
March 17, 2007, 03:03:08 PM »
Me again,
I DID manage to get Mach 3 up and It FOUND my GREX! YAY! It says initializing and then it says error 9991.... It boots me out of mach at that point... any suggestions?
M
ger21
6,295
Reply #2 on:
March 17, 2007, 03:22:34 PM »
Do you have the latest Mach3, the latest G100 plugin, and the latest firmware installed from the Geckodrive Yahoo group? You might want to read the last few days messages on the Yahoo group, there's a lot of G100 info there.
Last Edit: March 17, 2007, 03:27:04 PM by ger21
Print
Pages:
1
Go Up
« previous
next »
