Hello Guest it is November 21, 2026, 02:39:50 PM
Author Topic: Screen - Button Label - Multi-line  (Read 23555 times)
« on: May 07, 2014, 01:35:31 PM »
When entering multi-line text to a button label, I get a single line ... with small squares where the \n's were placed.
Duplicating (exactly) from other multi-line buttons has the same results.
I don't get it.  Any clues ?
Thanks.
Re: Screen - Button Label - Multi-line
« Reply #1 on: May 07, 2014, 02:04:07 PM »
OK,no problem.
FYI
It will show up in the button correctly after a shutdown and restart.
Also, edit the screen, exit edit mode and the Disable button then requires 2 clicks to reset.
It takes a shutdown and restart to correct this also.
All cool,
Russ
 8)
« Reply #2 on: May 08, 2014, 07:35:21 AM »
Sounds like we should be able to fix that..
www.newfangledsolutions.com
www.machsupport.com
