Hello Guest it is October 24, 2026, 07:00:12 AM
Author Topic: G28,M47 broke ?  (Read 61551 times)
Re: G28,M47 broke ?
« Reply #10 on: May 06, 2014, 10:26:02 PM »
Well with us older forgetfull dudes it is easier to remember G30 P4 than to remember where it actually is in Positional code  G53 X24.124 Y36.9876 Z6.78632 each time we need to revisit there. (;-)
Tools and service calls are very expensive .
Re: G28,M47 broke ?
« Reply #11 on: May 06, 2014, 10:39:23 PM »
Sorry, we are going to stick with the standard way point convention. I know it is odd but it is what we have all lived with for years.
Now if you would like to move to a position of the G30 you could look up the registers and do a g53.
G0 g90 G53 X[5181] Y[5182] Z[5183]
Not tested but it should work..  I use G53 because I hate G28 / G30
That way did not work but this way did.
#5181 = 1 #5182 =2 #5183=3 #5184 =4
G0 g90 G53 X#5181 Y#5182  Z#5183
Re: G28,M47 broke ?
« Reply #12 on: May 06, 2014, 10:57:47 PM »
Are the registers for the G30 suppose to be persistant ???
Re: G28,M47 broke ?
« Reply #13 on: May 06, 2014, 11:16:21 PM »
Yeah I can see that I forgot the # But you got the idea
Not at this time..
www.newfangledsolutions.com
www.machsupport.com
Re: G28,M47 broke ?
« Reply #14 on: May 06, 2014, 11:26:49 PM »
I was just curiuos as testing showed P1 and P3 are NOT persistant BUT P2 and P4 ARE persitant.   Where are the persistant values stored.
In Mach3 I have a Var report that I can search thru ALL the #vars and report their values.
It wouold be NICE to have one for MAch4.  Currently with #vars and params and Registers I am flying Blind.
(;-0 TP
Re: G28,M47 broke ?
« Reply #15 on: May 07, 2014, 10:25:33 AM »
I have a plugin here that will report the # vars. It has been added to the Reg plugin. It will be in the next release
Brian
www.machsupport.com
Re: G28,M47 broke ?
« Reply #16 on: May 07, 2014, 10:40:43 AM »
HIYA Brian I might be time to create a Mach4 dictionary the defines WHAT are all these things ( #var,#param, Registers)and WHAT they should be called officially to avoid confusion.
That way everyone speaks the same terms.
Just a thought, (;-) TP
Re: G28,M47 broke ?
« Reply #17 on: May 07, 2014, 10:43:35 AM »
I call them what you like but the  #var and #param  are stored in registers.. they are all the same sort of.
Brian
www.machsupport.com
Re: G28,M47 broke ?
« Reply #18 on: May 07, 2014, 10:55:23 AM »
I have always known them as
a # var such as #1 or A in a G65
A # param is a parameter for a function  such a #5061 A axis probe trip position OR set #9999 =1 to turn ON/OFF a function
A register is where these are stored and can be called anything as  Number or a Name
Re: G28,M47 broke ?
« Reply #19 on: May 08, 2014, 07:29:37 AM »
Yeah that is what I said... :)
www.machsupport.com
