Hello Guest it is November 22, 2026, 01:57:55 PM
Author Topic: Signal Scripts  (Read 39279 times)
Re: Signal Scripts
« Reply #20 on: July 19, 2014, 11:19:23 PM »
I'm digging this signal handling trick. The code for updating UI elements based on signal state only has to happen when the signal is sent.  Makes the PLC script way easier to maintain.
These are the kind of language "hacks" (meant in a really cool code way) that Lua supports that allows coders to be expressive.
-Freeman
I'm not a complete idiot...
    there are some parts missing.
Re: Signal Scripts
« Reply #21 on: July 19, 2014, 11:42:50 PM »
One thing I did notice, is if you add new signal handlers to your SigLib a restart of M4 is needed to pick them up.  You can change existing signal handlers without a restart though.
-Freeman
Re: Signal Scripts
« Reply #22 on: July 20, 2014, 04:15:20 PM »
Ya, I'm thinking mach4 has to read the machine.ini file to address the signal name correctly, thus the need for a restart. Hopefully these little details will be covered in the documentation.
Re: Signal Scripts
« Reply #23 on: July 22, 2014, 11:26:42 PM »
Signals become very interesting when you have a real motion device behind it.  The simulator doesn't appear to implement any input signals (ISIG_*).
Now that I have moved my screen set with signal handling installed over to my Sieg X3, I start to see how things like homing scripts are simple to implement.
If you would like to save some typing and monitor your signals, add the following to the bottom of your screen signal script:
Code: [Select]
local sigNames = {
    [mc.ISIG_DIGITIZE] = 'ISIG_DIGITIZE',
    [mc.ISIG_EMERGENCY] = 'ISIG_EMERGENCY',
    [mc.ISIG_INDEX] = 'ISIG_INDEX',
    [mc.ISIG_INPUT_FINISH] = 'ISIG_INPUT_FINISH',
    [mc.ISIG_INPUT_START] = 'ISIG_INPUT_START',
    [mc.ISIG_INPUT0] = 'ISIG_INPUT0',
    [mc.ISIG_INPUT1] = 'ISIG_INPUT1',
    [mc.ISIG_INPUT10] = 'ISIG_INPUT10',
    [mc.ISIG_INPUT11] = 'ISIG_INPUT11',
    [mc.ISIG_INPUT12] = 'ISIG_INPUT12',
    [mc.ISIG_INPUT13] = 'ISIG_INPUT13',
    [mc.ISIG_INPUT14] = 'ISIG_INPUT14',
    [mc.ISIG_INPUT15] = 'ISIG_INPUT15',
    [mc.ISIG_INPUT16] = 'ISIG_INPUT16',
    [mc.ISIG_INPUT17] = 'ISIG_INPUT17',
    [mc.ISIG_INPUT18] = 'ISIG_INPUT18',
    [mc.ISIG_INPUT19] = 'ISIG_INPUT19',
    [mc.ISIG_INPUT2] = 'ISIG_INPUT2',
    [mc.ISIG_INPUT20] = 'ISIG_INPUT20',
    [mc.ISIG_INPUT21] = 'ISIG_INPUT21',
    [mc.ISIG_INPUT22] = 'ISIG_INPUT22',
    [mc.ISIG_INPUT23] = 'ISIG_INPUT23',
    [mc.ISIG_INPUT24] = 'ISIG_INPUT24',
    [mc.ISIG_INPUT25] = 'ISIG_INPUT25',
    [mc.ISIG_INPUT26] = 'ISIG_INPUT26',
    [mc.ISIG_INPUT27] = 'ISIG_INPUT27',
    [mc.ISIG_INPUT28] = 'ISIG_INPUT28',
    [mc.ISIG_INPUT29] = 'ISIG_INPUT29',
    [mc.ISIG_INPUT3] = 'ISIG_INPUT3',
    [mc.ISIG_INPUT30] = 'ISIG_INPUT30',
    [mc.ISIG_INPUT31] = 'ISIG_INPUT31',
    [mc.ISIG_INPUT32] = 'ISIG_INPUT32',
    [mc.ISIG_INPUT33] = 'ISIG_INPUT33',
    [mc.ISIG_INPUT34] = 'ISIG_INPUT34',
    [mc.ISIG_INPUT35] = 'ISIG_INPUT35',
    [mc.ISIG_INPUT36] = 'ISIG_INPUT36',
    [mc.ISIG_INPUT37] = 'ISIG_INPUT37',
    [mc.ISIG_INPUT38] = 'ISIG_INPUT38',
    [mc.ISIG_INPUT39] = 'ISIG_INPUT39',
    [mc.ISIG_INPUT4] = 'ISIG_INPUT4',
    [mc.ISIG_INPUT40] = 'ISIG_INPUT40',
    [mc.ISIG_INPUT41] = 'ISIG_INPUT41',
    [mc.ISIG_INPUT42] = 'ISIG_INPUT42',
    [mc.ISIG_INPUT43] = 'ISIG_INPUT43',
    [mc.ISIG_INPUT44] = 'ISIG_INPUT44',
    [mc.ISIG_INPUT45] = 'ISIG_INPUT45',
    [mc.ISIG_INPUT46] = 'ISIG_INPUT46',
    [mc.ISIG_INPUT47] = 'ISIG_INPUT47',
    [mc.ISIG_INPUT48] = 'ISIG_INPUT48',
    [mc.ISIG_INPUT49] = 'ISIG_INPUT49',
    [mc.ISIG_INPUT5] = 'ISIG_INPUT5',
    [mc.ISIG_INPUT50] = 'ISIG_INPUT50',
    [mc.ISIG_INPUT51] = 'ISIG_INPUT51',
    [mc.ISIG_INPUT52] = 'ISIG_INPUT52',
    [mc.ISIG_INPUT53] = 'ISIG_INPUT53',
    [mc.ISIG_INPUT54] = 'ISIG_INPUT54',
    [mc.ISIG_INPUT55] = 'ISIG_INPUT55',
    [mc.ISIG_INPUT56] = 'ISIG_INPUT56',
    [mc.ISIG_INPUT57] = 'ISIG_INPUT57',
    [mc.ISIG_INPUT58] = 'ISIG_INPUT58',
    [mc.ISIG_INPUT59] = 'ISIG_INPUT59',
    [mc.ISIG_INPUT6] = 'ISIG_INPUT6',
    [mc.ISIG_INPUT60] = 'ISIG_INPUT60',
    [mc.ISIG_INPUT61] = 'ISIG_INPUT61',
    [mc.ISIG_INPUT62] = 'ISIG_INPUT62',
    [mc.ISIG_INPUT63] = 'ISIG_INPUT63',
    [mc.ISIG_INPUT7] = 'ISIG_INPUT7',
    [mc.ISIG_INPUT8] = 'ISIG_INPUT8',
    [mc.ISIG_INPUT9] = 'ISIG_INPUT9',
    [mc.ISIG_JOGAN] = 'ISIG_JOGAN',
    [mc.ISIG_JOGAP] = 'ISIG_JOGAP',
    [mc.ISIG_JOGBN] = 'ISIG_JOGBN',
    [mc.ISIG_JOGBP] = 'ISIG_JOGBP',
    [mc.ISIG_JOGCN] = 'ISIG_JOGCN',
    [mc.ISIG_JOGCP] = 'ISIG_JOGCP',
    [mc.ISIG_JOGXN] = 'ISIG_JOGXN',
    [mc.ISIG_JOGXP] = 'ISIG_JOGXP',
    [mc.ISIG_JOGYN] = 'ISIG_JOGYN',
    [mc.ISIG_JOGYP] = 'ISIG_JOGYP',
    [mc.ISIG_JOGZN] = 'ISIG_JOGZN',
    [mc.ISIG_JOGZP] = 'ISIG_JOGZP',
    [mc.ISIG_LIMITOVER] = 'ISIG_LIMITOVER',
    [mc.ISIG_MOTOR_HOME_FINISH] = 'ISIG_MOTOR_HOME_FINISH',
    [mc.ISIG_MOTOR_HOME_START] = 'ISIG_MOTOR_HOME_START',
    [mc.ISIG_MOTOR_MINUS_FINISH] = 'ISIG_MOTOR_MINUS_FINISH',
    [mc.ISIG_MOTOR_MINUS_START] = 'ISIG_MOTOR_MINUS_START',
    [mc.ISIG_MOTOR_PLUS_FINISH] = 'ISIG_MOTOR_PLUS_FINISH',
    [mc.ISIG_MOTOR_PLUS_START] = 'ISIG_MOTOR_PLUS_START',
    [mc.ISIG_MOTOR_START] = 'ISIG_MOTOR_START',
    [mc.ISIG_MOTOR0_HOME] = 'ISIG_MOTOR0_HOME',
    [mc.ISIG_MOTOR0_MINUS] = 'ISIG_MOTOR0_MINUS',
    [mc.ISIG_MOTOR0_PLUS] = 'ISIG_MOTOR0_PLUS',
    [mc.ISIG_MOTOR1_HOME] = 'ISIG_MOTOR1_HOME',
    [mc.ISIG_MOTOR1_MINUS] = 'ISIG_MOTOR1_MINUS',
    [mc.ISIG_MOTOR1_PLUS] = 'ISIG_MOTOR1_PLUS',
    [mc.ISIG_MOTOR10_HOME] = 'ISIG_MOTOR10_HOME',
    [mc.ISIG_MOTOR10_MINUS] = 'ISIG_MOTOR10_MINUS',
    [mc.ISIG_MOTOR10_PLUS] = 'ISIG_MOTOR10_PLUS',
    [mc.ISIG_MOTOR11_HOME] = 'ISIG_MOTOR11_HOME',
    [mc.ISIG_MOTOR11_MINUS] = 'ISIG_MOTOR11_MINUS',
    [mc.ISIG_MOTOR11_PLUS] = 'ISIG_MOTOR11_PLUS',
    [mc.ISIG_MOTOR12_HOME] = 'ISIG_MOTOR12_HOME',
    [mc.ISIG_MOTOR12_MINUS] = 'ISIG_MOTOR12_MINUS',
    [mc.ISIG_MOTOR12_PLUS] = 'ISIG_MOTOR12_PLUS',
    [mc.ISIG_MOTOR13_HOME] = 'ISIG_MOTOR13_HOME',
    [mc.ISIG_MOTOR13_MINUS] = 'ISIG_MOTOR13_MINUS',
    [mc.ISIG_MOTOR13_PLUS] = 'ISIG_MOTOR13_PLUS',
    [mc.ISIG_MOTOR14_HOME] = 'ISIG_MOTOR14_HOME',
    [mc.ISIG_MOTOR14_MINUS] = 'ISIG_MOTOR14_MINUS',
    [mc.ISIG_MOTOR14_PLUS] = 'ISIG_MOTOR14_PLUS',
    [mc.ISIG_MOTOR15_HOME] = 'ISIG_MOTOR15_HOME',
    [mc.ISIG_MOTOR15_MINUS] = 'ISIG_MOTOR15_MINUS',
    [mc.ISIG_MOTOR15_PLUS] = 'ISIG_MOTOR15_PLUS',
    [mc.ISIG_MOTOR16_HOME] = 'ISIG_MOTOR16_HOME',
    [mc.ISIG_MOTOR16_MINUS] = 'ISIG_MOTOR16_MINUS',
    [mc.ISIG_MOTOR16_PLUS] = 'ISIG_MOTOR16_PLUS',
    [mc.ISIG_MOTOR17_HOME] = 'ISIG_MOTOR17_HOME',
    [mc.ISIG_MOTOR17_MINUS] = 'ISIG_MOTOR17_MINUS',
    [mc.ISIG_MOTOR17_PLUS] = 'ISIG_MOTOR17_PLUS',
    [mc.ISIG_MOTOR18_HOME] = 'ISIG_MOTOR18_HOME',
    [mc.ISIG_MOTOR18_MINUS] = 'ISIG_MOTOR18_MINUS',
    [mc.ISIG_MOTOR18_PLUS] = 'ISIG_MOTOR18_PLUS',
    [mc.ISIG_MOTOR19_HOME] = 'ISIG_MOTOR19_HOME',
    [mc.ISIG_MOTOR19_MINUS] = 'ISIG_MOTOR19_MINUS',
    [mc.ISIG_MOTOR19_PLUS] = 'ISIG_MOTOR19_PLUS',
    [mc.ISIG_MOTOR2_HOME] = 'ISIG_MOTOR2_HOME',
    [mc.ISIG_MOTOR2_MINUS] = 'ISIG_MOTOR2_MINUS',
    [mc.ISIG_MOTOR2_PLUS] = 'ISIG_MOTOR2_PLUS',
    [mc.ISIG_MOTOR20_HOME] = 'ISIG_MOTOR20_HOME',
    [mc.ISIG_MOTOR20_MINUS] = 'ISIG_MOTOR20_MINUS',
    [mc.ISIG_MOTOR20_PLUS] = 'ISIG_MOTOR20_PLUS',
    [mc.ISIG_MOTOR21_HOME] = 'ISIG_MOTOR21_HOME',
    [mc.ISIG_MOTOR21_MINUS] = 'ISIG_MOTOR21_MINUS',
    [mc.ISIG_MOTOR21_PLUS] = 'ISIG_MOTOR21_PLUS',
    [mc.ISIG_MOTOR22_HOME] = 'ISIG_MOTOR22_HOME',
    [mc.ISIG_MOTOR22_MINUS] = 'ISIG_MOTOR22_MINUS',
    [mc.ISIG_MOTOR22_PLUS] = 'ISIG_MOTOR22_PLUS',
    [mc.ISIG_MOTOR23_HOME] = 'ISIG_MOTOR23_HOME',
    [mc.ISIG_MOTOR23_MINUS] = 'ISIG_MOTOR23_MINUS',
    [mc.ISIG_MOTOR23_PLUS] = 'ISIG_MOTOR23_PLUS',
    [mc.ISIG_MOTOR24_HOME] = 'ISIG_MOTOR24_HOME',
    [mc.ISIG_MOTOR24_MINUS] = 'ISIG_MOTOR24_MINUS',
    [mc.ISIG_MOTOR24_PLUS] = 'ISIG_MOTOR24_PLUS',
    [mc.ISIG_MOTOR25_HOME] = 'ISIG_MOTOR25_HOME',
    [mc.ISIG_MOTOR25_MINUS] = 'ISIG_MOTOR25_MINUS',
    [mc.ISIG_MOTOR25_PLUS] = 'ISIG_MOTOR25_PLUS',
    [mc.ISIG_MOTOR26_HOME] = 'ISIG_MOTOR26_HOME',
    [mc.ISIG_MOTOR26_MINUS] = 'ISIG_MOTOR26_MINUS',
    [mc.ISIG_MOTOR26_PLUS] = 'ISIG_MOTOR26_PLUS',
    [mc.ISIG_MOTOR27_HOME] = 'ISIG_MOTOR27_HOME',
    [mc.ISIG_MOTOR27_MINUS] = 'ISIG_MOTOR27_MINUS',
    [mc.ISIG_MOTOR27_PLUS] = 'ISIG_MOTOR27_PLUS',
    [mc.ISIG_MOTOR28_HOME] = 'ISIG_MOTOR28_HOME',
    [mc.ISIG_MOTOR28_MINUS] = 'ISIG_MOTOR28_MINUS',
    [mc.ISIG_MOTOR28_PLUS] = 'ISIG_MOTOR28_PLUS',
    [mc.ISIG_MOTOR29_HOME] = 'ISIG_MOTOR29_HOME',
    [mc.ISIG_MOTOR29_MINUS] = 'ISIG_MOTOR29_MINUS',
    [mc.ISIG_MOTOR29_PLUS] = 'ISIG_MOTOR29_PLUS',
    [mc.ISIG_MOTOR3_HOME] = 'ISIG_MOTOR3_HOME',
    [mc.ISIG_MOTOR3_MINUS] = 'ISIG_MOTOR3_MINUS',
    [mc.ISIG_MOTOR3_PLUS] = 'ISIG_MOTOR3_PLUS',
    [mc.ISIG_MOTOR30_HOME] = 'ISIG_MOTOR30_HOME',
    [mc.ISIG_MOTOR30_MINUS] = 'ISIG_MOTOR30_MINUS',
    [mc.ISIG_MOTOR30_PLUS] = 'ISIG_MOTOR30_PLUS',
    [mc.ISIG_MOTOR31_HOME] = 'ISIG_MOTOR31_HOME',
    [mc.ISIG_MOTOR31_MINUS] = 'ISIG_MOTOR31_MINUS',
    [mc.ISIG_MOTOR31_PLUS] = 'ISIG_MOTOR31_PLUS',
    [mc.ISIG_MOTOR4_HOME] = 'ISIG_MOTOR4_HOME',
    [mc.ISIG_MOTOR4_MINUS] = 'ISIG_MOTOR4_MINUS',
    [mc.ISIG_MOTOR4_PLUS] = 'ISIG_MOTOR4_PLUS',
    [mc.ISIG_MOTOR5_HOME] = 'ISIG_MOTOR5_HOME',
    [mc.ISIG_MOTOR5_MINUS] = 'ISIG_MOTOR5_MINUS',
    [mc.ISIG_MOTOR5_PLUS] = 'ISIG_MOTOR5_PLUS',
    [mc.ISIG_MOTOR6_HOME] = 'ISIG_MOTOR6_HOME',
    [mc.ISIG_MOTOR6_MINUS] = 'ISIG_MOTOR6_MINUS',
    [mc.ISIG_MOTOR6_PLUS] = 'ISIG_MOTOR6_PLUS',
    [mc.ISIG_MOTOR7_HOME] = 'ISIG_MOTOR7_HOME',
    [mc.ISIG_MOTOR7_MINUS] = 'ISIG_MOTOR7_MINUS',
    [mc.ISIG_MOTOR7_PLUS] = 'ISIG_MOTOR7_PLUS',
    [mc.ISIG_MOTOR8_HOME] = 'ISIG_MOTOR8_HOME',
    [mc.ISIG_MOTOR8_MINUS] = 'ISIG_MOTOR8_MINUS',
    [mc.ISIG_MOTOR8_PLUS] = 'ISIG_MOTOR8_PLUS',
    [mc.ISIG_MOTOR9_HOME] = 'ISIG_MOTOR9_HOME',
    [mc.ISIG_MOTOR9_MINUS] = 'ISIG_MOTOR9_MINUS',
    [mc.ISIG_MOTOR9_PLUS] = 'ISIG_MOTOR9_PLUS',
    [mc.ISIG_SPECIAL_FINISH] = 'ISIG_SPECIAL_FINISH',
    [mc.ISIG_SPECIAL_START] = 'ISIG_SPECIAL_START',
    [mc.ISIG_SPINDLE_AT_SPEED] = 'ISIG_SPINDLE_AT_SPEED',
    [mc.ISIG_SPINDLE_AT_ZERO] = 'ISIG_SPINDLE_AT_ZERO',
    [mc.ISIG_THCDOWN] = 'ISIG_THCDOWN',
    [mc.ISIG_THCON] = 'ISIG_THCON',
    [mc.ISIG_THCUP] = 'ISIG_THCUP',
    [mc.ISIG_TIMING] = 'ISIG_TIMING',
    [mc.MSG_SIG_CHANGED] = 'MSG_SIG_CHANGED',
    [mc.OSIG_AHOME] = 'OSIG_AHOME',
    [mc.OSIG_ALIMITMINUS] = 'OSIG_ALIMITMINUS',
    [mc.OSIG_ALIMITPLUS] = 'OSIG_ALIMITPLUS',
    [mc.OSIG_AXIS_SWITCH_FINISH] = 'OSIG_AXIS_SWITCH_FINISH',
    [mc.OSIG_AXIS_SWITCH_START] = 'OSIG_AXIS_SWITCH_START',
    [mc.OSIG_BHOME] = 'OSIG_BHOME',
    [mc.OSIG_BLIMITMINUS] = 'OSIG_BLIMITMINUS',
    [mc.OSIG_BLIMITPLUS] = 'OSIG_BLIMITPLUS',
    [mc.OSIG_BLOCK_DELETE] = 'OSIG_BLOCK_DELETE',
    [mc.OSIG_CHARGE] = 'OSIG_CHARGE',
    [mc.OSIG_CHARGE2] = 'OSIG_CHARGE2',
    [mc.OSIG_CHOME] = 'OSIG_CHOME',
    [mc.OSIG_CLIMITMINUS] = 'OSIG_CLIMITMINUS',
    [mc.OSIG_CLIMITPLUS] = 'OSIG_CLIMITPLUS',
    [mc.OSIG_COOLANTON] = 'OSIG_COOLANTON',
    [mc.OSIG_CURRENTHILOW] = 'OSIG_CURRENTHILOW',
    [mc.OSIG_DIGTRIGGER] = 'OSIG_DIGTRIGGER',
    [mc.OSIG_DIST_TOGO] = 'OSIG_DIST_TOGO',
    [mc.OSIG_DWELL] = 'OSIG_DWELL',
    [mc.OSIG_ENABLE_FINISH] = 'OSIG_ENABLE_FINISH',
    [mc.OSIG_ENABLE_START] = 'OSIG_ENABLE_START',
    [mc.OSIG_ENABLE0] = 'OSIG_ENABLE0',
    [mc.OSIG_ENABLE1] = 'OSIG_ENABLE1',
    [mc.OSIG_ENABLE10] = 'OSIG_ENABLE10',
    [mc.OSIG_ENABLE11] = 'OSIG_ENABLE11',
    [mc.OSIG_ENABLE12] = 'OSIG_ENABLE12',
    [mc.OSIG_ENABLE13] = 'OSIG_ENABLE13',
    [mc.OSIG_ENABLE14] = 'OSIG_ENABLE14',
    [mc.OSIG_ENABLE15] = 'OSIG_ENABLE15',
    [mc.OSIG_ENABLE16] = 'OSIG_ENABLE16',
    [mc.OSIG_ENABLE17] = 'OSIG_ENABLE17',
    [mc.OSIG_ENABLE18] = 'OSIG_ENABLE18',
    [mc.OSIG_ENABLE19] = 'OSIG_ENABLE19',
    [mc.OSIG_ENABLE2] = 'OSIG_ENABLE2',
    [mc.OSIG_ENABLE20] = 'OSIG_ENABLE20',
    [mc.OSIG_ENABLE21] = 'OSIG_ENABLE21',
    [mc.OSIG_ENABLE22] = 'OSIG_ENABLE22',
    [mc.OSIG_ENABLE23] = 'OSIG_ENABLE23',
    [mc.OSIG_ENABLE24] = 'OSIG_ENABLE24',
    [mc.OSIG_ENABLE25] = 'OSIG_ENABLE25',
    [mc.OSIG_ENABLE26] = 'OSIG_ENABLE26',
    [mc.OSIG_ENABLE27] = 'OSIG_ENABLE27',
    [mc.OSIG_ENABLE28] = 'OSIG_ENABLE28',
    [mc.OSIG_ENABLE29] = 'OSIG_ENABLE29',
    [mc.OSIG_ENABLE3] = 'OSIG_ENABLE3',
    [mc.OSIG_ENABLE30] = 'OSIG_ENABLE30',
    [mc.OSIG_ENABLE31] = 'OSIG_ENABLE31',
    [mc.OSIG_ENABLE4] = 'OSIG_ENABLE4',
    [mc.OSIG_ENABLE5] = 'OSIG_ENABLE5',
    [mc.OSIG_ENABLE6] = 'OSIG_ENABLE6',
    [mc.OSIG_ENABLE7] = 'OSIG_ENABLE7',
    [mc.OSIG_ENABLE8] = 'OSIG_ENABLE8',
    [mc.OSIG_ENABLE9] = 'OSIG_ENABLE9',
    [mc.OSIG_FEEDHOLD] = 'OSIG_FEEDHOLD',
    [mc.OSIG_HOMED_A] = 'OSIG_HOMED_A',
    [mc.OSIG_HOMED_B] = 'OSIG_HOMED_B',
    [mc.OSIG_HOMED_C] = 'OSIG_HOMED_C',
    [mc.OSIG_HOMED_X] = 'OSIG_HOMED_X',
    [mc.OSIG_HOMED_Y] = 'OSIG_HOMED_Y',
    [mc.OSIG_HOMED_Z] = 'OSIG_HOMED_Z',
    [mc.OSIG_JOG_CONT] = 'OSIG_JOG_CONT',
    [mc.OSIG_JOG_ENABLED] = 'OSIG_JOG_ENABLED',
    [mc.OSIG_JOG_INC] = 'OSIG_JOG_INC',
    [mc.OSIG_JOG_MPG] = 'OSIG_JOG_MPG',
    [mc.OSIG_LIMITOVER] = 'OSIG_LIMITOVER',
    [mc.OSIG_MACHINE_CORD] = 'OSIG_MACHINE_CORD',
    [mc.OSIG_MACHINE_ENABLED] = 'OSIG_MACHINE_ENABLED',
    [mc.OSIG_MISC_FINISH] = 'OSIG_MISC_FINISH',
    [mc.OSIG_MISC_START] = 'OSIG_MISC_START',
    [mc.OSIG_MISTON] = 'OSIG_MISTON',
    [mc.OSIG_OPT_STOP] = 'OSIG_OPT_STOP',
    [mc.OSIG_OUTPUT_FINISH] = 'OSIG_OUTPUT_FINISH',
    [mc.OSIG_OUTPUT_START] = 'OSIG_OUTPUT_START',
    [mc.OSIG_OUTPUT0] = 'OSIG_OUTPUT0',
    [mc.OSIG_OUTPUT1] = 'OSIG_OUTPUT1',
    [mc.OSIG_OUTPUT10] = 'OSIG_OUTPUT10',
    [mc.OSIG_OUTPUT11] = 'OSIG_OUTPUT11',
    [mc.OSIG_OUTPUT12] = 'OSIG_OUTPUT12',
    [mc.OSIG_OUTPUT13] = 'OSIG_OUTPUT13',
    [mc.OSIG_OUTPUT14] = 'OSIG_OUTPUT14',
    [mc.OSIG_OUTPUT15] = 'OSIG_OUTPUT15',
    [mc.OSIG_OUTPUT16] = 'OSIG_OUTPUT16',
    [mc.OSIG_OUTPUT17] = 'OSIG_OUTPUT17',
    [mc.OSIG_OUTPUT18] = 'OSIG_OUTPUT18',
    [mc.OSIG_OUTPUT19] = 'OSIG_OUTPUT19',
    [mc.OSIG_OUTPUT2] = 'OSIG_OUTPUT2',
    [mc.OSIG_OUTPUT20] = 'OSIG_OUTPUT20',
    [mc.OSIG_OUTPUT21] = 'OSIG_OUTPUT21',
    [mc.OSIG_OUTPUT22] = 'OSIG_OUTPUT22',
    [mc.OSIG_OUTPUT23] = 'OSIG_OUTPUT23',
    [mc.OSIG_OUTPUT24] = 'OSIG_OUTPUT24',
    [mc.OSIG_OUTPUT25] = 'OSIG_OUTPUT25',
    [mc.OSIG_OUTPUT26] = 'OSIG_OUTPUT26',
    [mc.OSIG_OUTPUT27] = 'OSIG_OUTPUT27',
    [mc.OSIG_OUTPUT28] = 'OSIG_OUTPUT28',
    [mc.OSIG_OUTPUT29] = 'OSIG_OUTPUT29',
    [mc.OSIG_OUTPUT3] = 'OSIG_OUTPUT3',
    [mc.OSIG_OUTPUT30] = 'OSIG_OUTPUT30',
    [mc.OSIG_OUTPUT31] = 'OSIG_OUTPUT31',
    [mc.OSIG_OUTPUT32] = 'OSIG_OUTPUT32',
    [mc.OSIG_OUTPUT33] = 'OSIG_OUTPUT33',
    [mc.OSIG_OUTPUT34] = 'OSIG_OUTPUT34',
    [mc.OSIG_OUTPUT35] = 'OSIG_OUTPUT35',
    [mc.OSIG_OUTPUT36] = 'OSIG_OUTPUT36',
    [mc.OSIG_OUTPUT37] = 'OSIG_OUTPUT37',
    [mc.OSIG_OUTPUT38] = 'OSIG_OUTPUT38',
    [mc.OSIG_OUTPUT39] = 'OSIG_OUTPUT39',
    [mc.OSIG_OUTPUT4] = 'OSIG_OUTPUT4',
    [mc.OSIG_OUTPUT40] = 'OSIG_OUTPUT40',
    [mc.OSIG_OUTPUT41] = 'OSIG_OUTPUT41',
    [mc.OSIG_OUTPUT42] = 'OSIG_OUTPUT42',
    [mc.OSIG_OUTPUT43] = 'OSIG_OUTPUT43',
    [mc.OSIG_OUTPUT44] = 'OSIG_OUTPUT44',
    [mc.OSIG_OUTPUT45] = 'OSIG_OUTPUT45',
    [mc.OSIG_OUTPUT46] = 'OSIG_OUTPUT46',
    [mc.OSIG_OUTPUT47] = 'OSIG_OUTPUT47',
    [mc.OSIG_OUTPUT48] = 'OSIG_OUTPUT48',
    [mc.OSIG_OUTPUT49] = 'OSIG_OUTPUT49',
    [mc.OSIG_OUTPUT5] = 'OSIG_OUTPUT5',
    [mc.OSIG_OUTPUT50] = 'OSIG_OUTPUT50',
    [mc.OSIG_OUTPUT51] = 'OSIG_OUTPUT51',
    [mc.OSIG_OUTPUT52] = 'OSIG_OUTPUT52',
    [mc.OSIG_OUTPUT53] = 'OSIG_OUTPUT53',
    [mc.OSIG_OUTPUT54] = 'OSIG_OUTPUT54',
    [mc.OSIG_OUTPUT55] = 'OSIG_OUTPUT55',
    [mc.OSIG_OUTPUT56] = 'OSIG_OUTPUT56',
    [mc.OSIG_OUTPUT57] = 'OSIG_OUTPUT57',
    [mc.OSIG_OUTPUT58] = 'OSIG_OUTPUT58',
    [mc.OSIG_OUTPUT59] = 'OSIG_OUTPUT59',
    [mc.OSIG_OUTPUT6] = 'OSIG_OUTPUT6',
    [mc.OSIG_OUTPUT60] = 'OSIG_OUTPUT60',
    [mc.OSIG_OUTPUT61] = 'OSIG_OUTPUT61',
    [mc.OSIG_OUTPUT62] = 'OSIG_OUTPUT62',
    [mc.OSIG_OUTPUT63] = 'OSIG_OUTPUT63',
    [mc.OSIG_OUTPUT7] = 'OSIG_OUTPUT7',
    [mc.OSIG_OUTPUT8] = 'OSIG_OUTPUT8',
    [mc.OSIG_OUTPUT9] = 'OSIG_OUTPUT9',
    [mc.OSIG_REVERSE_RUN] = 'OSIG_REVERSE_RUN',
    [mc.OSIG_RUNNING_GCODE] = 'OSIG_RUNNING_GCODE',
    [mc.OSIG_SINGLE_BLOCK] = 'OSIG_SINGLE_BLOCK',
    [mc.OSIG_SOFTLIMITS_ON] = 'OSIG_SOFTLIMITS_ON',
    [mc.OSIG_SPINDLEFWD] = 'OSIG_SPINDLEFWD',
    [mc.OSIG_SPINDLEON] = 'OSIG_SPINDLEON',
    [mc.OSIG_SPINDLEREV] = 'OSIG_SPINDLEREV',
    [mc.OSIG_TOOL_CHANGE] = 'OSIG_TOOL_CHANGE',
    [mc.OSIG_TP_MOUSE_DN] = 'OSIG_TP_MOUSE_DN',
    [mc.OSIG_XHOME] = 'OSIG_XHOME',
    [mc.OSIG_XLIMITMINUS] = 'OSIG_XLIMITMINUS',
    [mc.OSIG_XLIMITPLUS] = 'OSIG_XLIMITPLUS',
    [mc.OSIG_YHOME] = 'OSIG_YHOME',
    [mc.OSIG_YLIMITMINUS] = 'OSIG_YLIMITMINUS',
    [mc.OSIG_YLIMITPLUS] = 'OSIG_YLIMITPLUS',
    [mc.OSIG_ZHOME] = 'OSIG_ZHOME',
    [mc.OSIG_ZLIMITMINUS] = 'OSIG_ZLIMITMINUS',
    [mc.OSIG_ZLIMITPLUS] = 'OSIG_ZLIMITPLUS',
    [mc.SIG_TYPE_INPUT] = 'SIG_TYPE_INPUT',
    [mc.SIG_TYPE_NONE] = 'SIG_TYPE_NONE',
    [mc.SIG_TYPE_OUTPUT] = 'SIG_TYPE_OUTPUT',
if(SigLib[sig] ~= nil)then
    local sigName = sigNames[sig] or sig;
    mc.mcCntlSetLastError(inst,'State - '..sigName..' = '..tostring(state));
    SigLib[sig](state);  -- comment out if you don't have any SigLib definitions in your screen startup script.
end
A sample history log from my X3 looks like:
Code: [Select]
State - ISIG_MOTOR0_HOME = 1
State - OSIG_HOME_START: 1
State - OSIG_HOMED_X = 1
-Freeman
« Last Edit: July 22, 2014, 11:40:06 PM by Analias »
Re: Signal Scripts
« Reply #24 on: July 23, 2014, 08:44:59 AM »
thats pretty cool, but it does not display the spindle or coolant on and off, wonder why?
probably a few more, but just starting to play
did reformat it a little cause i'm a little  >:D
Code: [Select]
local sigNames = {
end
this is the startup and a gcode file run
Though did just notice that the M30 does not turn off the spindle
Update: found it is possible to create a M30 macro and solve that issue.  ;)
Code: [Select]
State - SIG_TYPE_OUTPUT = 0
State - ISIG_INPUT2 = 0
State - ISIG_INPUT3 = 0
State - ISIG_INPUT4 = 0
State - ISIG_INPUT5 = 0
State - ISIG_INPUT6 = 0
State - ISIG_INPUT7 = 0
State - ISIG_INPUT8 = 0
State - ISIG_INPUT13 = 0
State - ISIG_INPUT14 = 0
State - ISIG_INPUT15 = 0
State - OSIG_RUNNING_GCODE = 0
State - OSIG_MACHINE_ENABLED = 0
State - OSIG_MACHINE_ENABLED = 1
Do Cycle Start
State - OSIG_RUNNING_GCODE = 1
« Last Edit: July 23, 2014, 10:31:17 AM by Ya-Nvr-No »
Offline TimGS
  •  108 108
Re: Signal Scripts
« Reply #25 on: May 06, 2015, 09:56:51 AM »
Could you explain what is meant by the [] = assignment?  Thank You
Offline TimGS
  •  108 108
Re: Signal Scripts
« Reply #26 on: May 06, 2015, 10:17:19 AM »
Found it...
Suppose you want to list all identifiers used in a program source; somehow you need to filter the reserved words out of your listing. Some C programmers could be tempted to represent the set of reserved words as an array of strings, and then to search this array to know whether a given word is in the set. To speed up the search, they could even use a binary tree or a hash table to represent the set.
http://www.lua.org/pil/11.5.html
In Lua, an efficient and simple way to represent such sets is to put the set elements as indices in a table. Then, instead of searching the table for a given element, you just index the table and test whether the result is nil or not. In our example, we could write the next code:
    reserved = {
      ["while"] = true,     ["end"] = true,
      ["function"] = true,  ["local"] = true,
