Hello Guest it is November 13, 2026, 02:02:51 PM
Author Topic: Odd behavior with probe wiring  (Read 33859 times)
Offline mbele
  •  58 58
Re: Odd behavior with probe wiring
« Reply #10 on: May 04, 2014, 10:17:04 AM »
C10 inputs are normaly grounded when left in the air, so you have to supply +5V to bring them up or modify BOB so that input is normaly high.
Try doing a test with router unplugged. Try measuring voltage between tool and BOB ground when router is plugged in (AC and DC). That may give you clues what's going on.
I think that all this can be avoided if tool is grounded on BOB side only and pull up resistor is used on input like i described earlier...My Kress is not normaly grounded via AC plug...
I wanted to do similar thing (isolate router from frame) so i could use moving bed/table instead of PCB to close connection... but figured it was asking for trouble :)
« Reply #11 on: May 04, 2014, 10:41:52 AM »
Between the router casing and the router frame there's .5 volt AC when the router plug is connected. When the router plug is unconnected, the voltage drops to zero.
I switched from a Bausch to the current Hitachi, and I don't remember this being a problem, way back, when I had tried to use a probe. I eventually disconnected the probe due to breaking too many copper pads during a period of intense production, and I didn't have time to truly learn how to use it.
Also, Mach 3 does not find pin 13 during an autoselect routine. It keeps going to 12 for two separate switches. Perhaps the BOB is broken, although when I use the pin as described earlier, it works fine.
So, do we connect the AC ground to the DC power supply ground? I may have done so, but need to check....
tony
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: May 04, 2014, 11:01:52 AM »
When the plate is connected to the input line, and the alligator is connected to the "power ground" on the breakout board, the circuit simply does not work, regardless of how I set Mach 3 input states.
tony
Saying the "the circuit simply does not work" is not the most helpful description of what's happening.
With the input connected to the plate and set in Mach to active LOW and doing NOTHING with the clip - is the input LED in Mach lit or un-lit?
« Reply #13 on: May 04, 2014, 11:54:21 AM »
Since the Hitachi routers is the latest addition to my  cnc, the fact that I am reading an AC voltage between the casing and the cnc frame is troubling.
I am reading upwards of 24 volts when the unit is plugged into the socket.
It has a three wire line, and one is grounded. But I don't think there should be voltage floating around the casing.
I purchased as a factory refurbished unit, but this voltage bothers me.
tony
« Reply #14 on: May 05, 2014, 04:09:17 PM »
So, I grounded the hitachi router to the machine. I changed the BOB to a new one, fearing that I had damaged a few inputs during my testing with the other board.
Currently, all the input ports are such that if I short an input line to 5+, Mach3 input LED lights up. I've done this test with all inputs and they all behave the same.
Now that the tool bit is grounded to the machine, I need to figure out how to do the following with these pins:
1. Wire only the homing switches
2. wire a probe
I would appreciate some direction. I connected a 10K resistor between  an input line and +5. When I ground the input , however, nothing happensin Mach 3, even when I change the check box to active low.
Do I need to reverse the BOB jumpers so that all the input lines become active low?  If so, how would I then connect the homing switches.
I confess that given the popularity of the cnc4pc, there are things about these boards that are still not explained in a more 1-2-3 fashion..... but perhaps it's me. It's the probe connection that has thrown me into the abyss.
thanks in advance.
tony
Offline mbele
  •  58 58
« Reply #15 on: May 06, 2014, 12:37:55 AM »
Are you sure that jumper exists (my board does not have it) ?
"Active" state is logic state, inputs can have "high" and "low" state, you can set logic state in Mach and tell him how to interpret input state into active state. If you actually do have jumper that can make inputs "high" when left in the air, then you do not need resistor and you do not have to connect +5V to the input since it will be "high" allreaday. If not, try 2.2K resistor betwen input and +5V instead of 10K -  I think you'll have to have one resistor for each input you want to use that way (thats how I have it wired, all my inputs are pulled high, someone correct me if I'm wrong).
Then wire your switches and/or probe so they are "N.O." - normaly open. When contact is closed it should bring 0V line to input pin (bringing it "down" into "low" state). Mach should be configured for that input(s) so that active state is low ("Active low").
Now, I have 0VDC and AC ground on the same potential - my PSU has it internaly shorted, but your PSU most probably may not have it, so you'll have to short it yourself so you bring 0VDC to tool. Since your tool is now grounded (probably via router frame) and ground is shorted to 0VDC, it may introduce noise into system, so you may need to use capacitor (0.1uF) between input line and ground to filter it out (capacitor lets AC pass and blocks DC) - i do not need/use it, and I have only read about it (no expirience there).
BTW. re AC ground and 0VDC, 0VDC is reference potential for signal lines from which DC voltages are measured, and AC ground is used for safety, so that if any current appears on metal parts exposed to touch (where it would be hazardous) it would go to ground through that wire instead through you.
For the conversation sake, what would happen if 24VAC present on router case/tool was sent to ground via capacitor ? Does it depend on the current source/magnitude available on that 24VAC, and if so how can that current magnitude be measured ?
« Reply #16 on: May 06, 2014, 04:14:17 AM »
thank you very much for the very clear explanation.  The first board did not have jumpers( I think it was rev 8). The replacement board has jumpers.  The multimeter shows a solid contact between the board ground and the machine frame, and with the router to the frame.
From your explanation, it's clear that my other board was connected so that the input were normally low. Now I will make them high so that the probe plate will be wired to the input and the alligator clip will be wire to the tool, which will bring the  input pin low.
tony
Offline mbele
  •  58 58
« Reply #17 on: May 06, 2014, 04:29:32 AM »
:) I'm glad I was able to help. If your 0VDC (i guess you call it "board ground") is always connected to router frame and the frame is connected to router/tool, you do not need aligator clip since the tool is allready connected to 0VDC. Also, if one jumper changes all of the input pins to be "high" when left in the air, you'll have to apply same logic to your inputs (home/limit switches etc). Good luck!
Mihael
Offline stirling
  •  2,188 2,188
  • UK
« Reply #18 on: May 06, 2014, 06:33:57 AM »
Which is what I suggested you do back in post #7. Anyway - you got there.
« Reply #19 on: May 06, 2014, 07:30:24 AM »
You are correct, Stirling. The reason why I'been sheepish about all of these things is that I had already burned one board, and could not afford to burn a second one without fully understanding the wiring.
So, I have the new board working by having the input lines jumper in a "pull down" mode.  The probe test has a resistor going from +5 to the input line. When this line is grounded, the circuit is active pulled down and triggers an action.
Here's my question:  Does this mean that for the home switches and the E stop I need to have resistors going to the input lines. This is where the cnc4pc documentation is not very clear, at least for me.
I am not willing to test the other input functions without a resistor for fear that I may blow the board.
So, my question:
Do I need to have resistors for all the other switch functions?
thanks for the great help
tony
